Monitor dies with "Too many open files" error
Morning,
We have recently upgraded our GRASS computer system from Solaris 2.5 to 2.5.1 o
n
Sparc, and now seem to have a problem with the monitor processes dying in a
random way with a "Too many open files" error. This problem was not seen with
Solaris 2.5
This is normally a UNIX error message, indicating that there are insufficient
file descriptors available. I have increased this number from 128 to 512 on the
system (see below for system descriptions), but this hasn't made any difference
Similarly a recompilation of the GRASS source has not corrected the problem
either.
The only other difference that I can think of is that the GRASS system now a
faster computer and there is some timing issue here that was not seen on the
slower Sparc 5 that used to run this software.
The installation is somewhat non standard in that the GRASS binary is not
installed as a standalone application. The binary is NFS mounted off a shared
disk to the other computers that use grass for processing.
The new installation uses an Ultrasparc as the server and Sparc 4s as "clients"
the old system used a Sparc 5 as the server and Sparc IPXs as clients. As
mentioned above each user has had the file descriptor limit increased to 512.
Investigation of the problem using 'lsof' (a pubic domain file list generator)
indicates that the XDRIVER opens up four files when started from d.mon.
At some time during the operation of the system the XDRIVER process starts
opening further files at the rate of about one per second. These files are not
closed, with the eventual failure of the monitor with a "too many files open"
error.
Does anyone have any ideas on what might be causing this problem?
Karl
Karl Nissen Phone: (+61 6) 249 4613
Department of Geography, SRMES Fax: (+61 6) 249 3770
The Australian National University e-mail: karl@dart.anu.edu.au
