monitor locking process error
Dear Grass-users,
        Have installed grass4.1.5 including update patch1 and Linux slackware3
with kernel 1.2.13 in umsdos mode on a Compaq Presario 5522
after splitting my harddisk with fips.Run win95 on the other part.
Video chip set S3-Trio64
        Everything seems fine exept:
When I try d.mon start=x0 or d.mon select=x0 ,a monitor comes up but
then the following message:
$:Error - Could not complete locking process for monitor <x0>
  Lockfile is /usr/local/grass/locks/darkstar/mon.4721494
Being a total novice to both Linux and Grass Im at a loss at this one.
Suspect a problem with memory or initab file.Help Help Help.....
Thanks in advance
Roland Muench - Landscape Architect
Darwin-Northern Territory-Australia
roland@taunet.net.au
On Sat, 27 Apr 1996, roland muench wrote:
Dear Grass-users,
Check permissions of the file! and the subdirectories! should be writable
so that starting a monitor will remove the file!
                        Bart
        | ir. Bart Cosyn |
        | VLIR-project Tunisia |
        | Laboratory for Hydrology and Water Management |
        | University of Gent |
        | Coupure 653, B-9000 Gent |
     | Belgium |
        | Tel: +/32/9/2646137 |
        | Fax: +/32/9/2646236 |
        | E-mail: Bart.Cosyn@rug.ac.be |
        | URL: http://taoren.rug.ac.be/ |
