Monitor Size
In an E-mail message, Conn Copas wrote:
Amy writes:
"How can I specify what size the
monitor will be __right__ after
I open it with 'd.mon'? I'm writing
a script and would prefer that the
user does not have to enlarge the
monitor before displaying any maps.
Please respond directly to me."
I recently hacked the X driver to do something which may be of general interest
so, if you can stand a small amount of C code, here it is. The idea is that the
default aspect ratio of the monitor reflects the aspect ratio of the data
within the current region, unless this is overridden by the presence of
XDRIVER_HEIGHT/WIDTH environment variables. So, no more ugly black borders
around rectangular data within square monitors. Also, if you zoom into some
tiny region, the monitor is magnified to a size which occupies a reasonable
amount of screen real-estate; around 20%. If the monitor is resized
interactively, the aspect ratio is preserved.
Hello Conn,
I tried your XDRIVER code change but was not able to see any effect from
it. When I started a monitor, a square monitor came up and maps dispayed
to it had black borders on the left and right sides. I also saw no effect
when I zoomed and displayed maps. The compile seemed to work fine but did
result in a warning for lines 322 and 323 in the Graph_Set.c code where you
made changes:
cc -O -D_NO_PROTO -I/usr/openwin/include -I/data/softail/loechl/grass_up4/grass
.src/src/include -c Graph_Set.c
"Graph_Set.c", line 322: warning: struct/union or struct/union pointer required
"Graph_Set.c", line 323: warning: struct/union or struct/union pointer required
mv Graph_Set.o OBJ.sun4/Graph_Set.o
rm -f OBJ.sun4/Panel.o
The relevant lines in Graph_Set.c are shown below. Any ideas on what happened?
get_aspect(pref_rows,pref_cols,me,dpy, scrn)
int *pref_rows, *pref_cols;
char *me;
    float rows, cols, row_frac, col_frac, side, temp;
    int mag = 1;
    int x, y;
        get_user ("XDRIVER_HEIGHT",pref_rows,0);
        get_user ("XDRIVER_WIDTH",pref_cols,0);
        if (*pref_rows <= 0 || *pref_cols <= 0)
        G_gisinit(me);
        rows = G_window_rows();
        cols = G_window_cols();
row_frac = rows/DisplayHeight(dpy, scrn);
col_frac = cols/DisplayWidth(dpy, scrn);
        if (rows > cols)
                side = row_frac;
        else
                side = col_frac;
        do
                mag++;
                temp = mag*side;
        while (temp <= 0.5);
        *pref_rows = rows*--mag;
        *pref_cols = cols*mag;
Paul Loechl p-loechl@cecer.army.mil
USA CERL (217)352-6511x7668
