more digitizer
Kathy,
It sounds like you need to compile src/mapdev/digitizers/calcomp. You should
be able to cd to this directory and run gmake4.1, then run the MAKELINKS
command.
Hope this works for you!
Thank you to Malcolm Williamson and Ken Sibley for responding to my
question about setting up the CALCOMP digitizer. I think we figured out
which available digitizer we need "cc95f6_16", however it also appears
that we need a subdirectory in the etc/dig_drivers directory corresponding
to the digitizer and that we need to change the ownership on this to "root".
  Our dig_driver directory has only 2 subdirectories "kurta" and "kurta2".
  What do we need to do to get an appropriate subdirectory set up? Also
am I missing something, or can I assume that setting up the subdirectory in
the dig_drivers directory will be the last step, assuming the "cc95f6_16" is
the correct format for our digitizer?
Thanks for any light you may be able to shed on this issue.
Kathy Doyle
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
