more digitizer
Thank you to Malcolm Williamson and Ken Sibley for responding to my
question about setting up the CALCOMP digitizer. I think we figured out
which available digitizer we need "cc95f6_16", however it also appears
that we need a subdirectory in the etc/dig_drivers directory corresponding
to the digitizer and that we need to change the ownership on this to "root".
  Our dig_driver directory has only 2 subdirectories "kurta" and "kurta2".
  What do we need to do to get an appropriate subdirectory set up? Also
am I missing something, or can I assume that setting up the subdirectory in
the dig_drivers directory will be the last step, assuming the "cc95f6_16" is
the correct format for our digitizer?
Thanks for any light you may be able to shed on this issue.
Kathy Doyle
Kathy,
I beleive that the dig_drivers directory is not needed. From what I know the dig_drivers/*
files are for the old v.digit, ie. pre grass4.1, now called v.digit2 in grass4.1.
If someone else knows more about this feel free to explain/correct where needed.
Ken Sibley
USDA-SCS
ksibley@ncg.scs.ag.gov
