more ERDAS
One question that hasn't been fully addressed; Does the ERDAS command cvt73
convert ver. 7.5 files to 7.3 format? Entries to the list seem to indicate
it has been done, while colleagues at CSU have been unsuccessful in converting
7.5 to 7.3 using cvt73. A file is created, but it won't import to GRASS via
r.in.erdas. The usefulness of ERDAS cvt73 wll determine the future
effectiveness of GRASS r.in.erdas.
   Ronald Thomas ^ ront@meeker.cfnr.colostate.edu
    Natural Resources Spec. (GIS) ^
     Resources Management Division ^ Phone: 303-586-3565 x285
      Rocky Mountain National Park ^ 700-323-7285 (FTS)
       Estes Park, CO 80517 ^ FAX: 303-586-4702
To run GRASS r.in.erdas command to convert ERDAS ".lan" or ".gis" file into
GRASS raster format, you have to convert ERDAS 7.4 or 7.5 format into 7.3. With
using ERDAS version 7.5, we had successfully used "cvt73" command to convert
7.5 header into 7.3, which is readable by GRASS r.in.erdas.
When you run r.in.erdas, please make sure that the inupt erdas 7.3 filename
has full name entered (including extension name, such as "image.gis") and
corresponding trailer file name with extention name (".trl" or ".sta") entered.
The trailer file is built by ERDAS command "BSTATS".
If the above option doesn't work for some reason on your sites, please try the
general conversion routine with ERDAS DMPDATA command, then you could either
directly move the output file into $LOCATION/cell directory or use i.tape.other
read the output disk file (multi-bands) into a GRASS image group.
Good Luck.
# # ## # # #### Wang Song (wang)
# # # # # # # # Center for Advanced Spatial Technologies
# ## # ###### # # # # ### 12 Ozark Hall
## ## # # # ## # # University of Arkansas
# # # # # # #### Fayetteville, AR 72701
INTERNET: wang@cast.uark.edu Tel: (501) 575-6159
                                   FAX: (501) 575-3846
