flogden@hml.uiowa.edu (Fred Ogden) writes:
Hello fellow GRASS users.
I've been fortunate in the past to have data sets well within UTM zones.
Unfortunately, that happy period is at an end. I am dealing with county soils
and land use data for Oklahoma which is split between zones 14 and 15. What I
want to do is bring the raster map for a county in zone 15, and patch it with
a raster map in zone 14.
Fred L. Ogden
Iowa Institute of Hydraulic Research
The University of Iowa
Iowa City, IA 52242
I checked my archives, because I recalled dealing with this before.
Here is a shellscript that was kindly sent to me by Scott Wade some
time ago. I think it will help you with your task...
Chris Rewerts
---------------------------8<-------------------------------
#!/bin/sh
# UTM ZONE TRANSFORMATION SCRIPT FOR GRASS VECTOR DATA
# This Bourne shell script, for use in GRASS4.0, transforms GRASS
# vector data from one UTM zone to another. This would typically be
# needed where a location straddles the boundary between two UTM zones.
# For the entire data set in the location to be sensible, one of the
# zones needs to be 'extended' to encompass all of the available data.
# All dig and dig_ascii vector data in the current mapset search path
# (not just the current mapset) can potentially be transformed. All
# results are stored as binary dig layers in the current mapset.
# The script is loosely based on a GRASS3 C-shell script written by Kenn
# Gardels, University of California, Berkeley. His reference: Department
# of the Army (1973), "Universal Transverse Mercator Grid Technical Manual",
# TM 5-241-8.
# This script was written in June 1992 by Scott Wade, Spatial Analysis and
# Systems Team, US Army Corps of Engineers Construction Engineering Research
# Laboratories [ wade@zorro.cecer.army.mil ].
# WARNING: This script has not been extensively tested.
# WARNING: The Clarke 1866 spheroid is assumed.
# Determine if GRASS is being used
if [ ! "$GISBASE" ]
then
echo ""
echo "ERROR: must be in GRASS to use `basename $0`"
echo ""
exit
fi
# Request needed information from user
echo ""
echo -n "Enter old UTM zone (zone to be converted FROM): "
read OLDZONE
echo ""
if [ "$OLDZONE" -lt "1" -o "$OLDZONE" -gt "60" ]
then
echo "ERROR: invalid UTM zone: $OLDZONE"
echo ""
exit
fi
echo -n "Enter new UTM zone (zone to be converted TO): "
read NEWZONE
echo ""
if [ "$NEWZONE" -lt "1" -o "$NEWZONE" -gt "60" ]
then
echo "ERROR: invalid UTM zone: $NEWZONE"
echo ""
exit
fi
if [ "$NEWZONE" -eq "$OLDZONE" ]
then
echo "New zone same as old zone; no tranformation performed."
echo ""
exit
fi
echo "Enter layer(s) to be converted from zone $OLDZONE to zone $NEWZONE,"
echo "separated by spaces."
echo ""
echo -n "> "
read THELAYERS
echo ""
if [ "$THELAYERS" = "" ]
then
exit
fi
# Beginning of loop
for LAYER in $THELAYERS
do
# Search for the dig_ascii file in the current mapset search path.
# If not found, seaarch for the dig layer. If neither are found,
# move on to the next named layer.
# The use of g.findfile and eval sets the variables $file and $mapset.
eval `g.findfile element=dig_ascii file=$LAYER`
if [ "$file" ]
then
DOIT=ASCII
else
eval `g.findfile element=dig file=$LAYER`
if [ "$file" ]
then
DOIT=binary
# If needed, convert old zone binary dig data to old zone dig_ascii file
v.out.ascii input=$LAYER output=$LAYER.old
else
DOIT=n
echo ""
echo "ERROR: layer $LAYER"
echo "Neither dig nor dig_ascii file found in current mapset search path."
echo ""
fi
fi
if [ "$DOIT" = "ASCII" -o "$DOIT" = "binary" ]
then
echo ""
echo -n "Converting $DOIT $LAYER to binary $LAYER.shift ..."
# Convert old zone UTM ASCII data to old zone lat/long ASCII data.
# Lat/long is used as a 'data standard' for the transformation.
# The old-zone data is exported to lat/long, then later imported
# back into UTM using the new zone.
if [ "$DOIT" = "binary" ]
then
m.u2ll -r spheroid=clark66 zone=$OLDZONE input=$LOCATION/dig_ascii/$LAYER.old output=$LOCATION/dig_ascii/$LAYER.ll
else
m.u2ll -r spheroid=clark66 zone=$OLDZONE input=$LOCATION/dig_ascii/$LAYER output=$LOCATION/dig_ascii/$LAYER.ll
fi
if [ $? -ne 0 ]
then
echo ""
echo "Problem using m.u2ll for layer $LAYER"
echo ""
exit
fi
echo -n "..."
# remove unneeded file
if [ -f "$LOCATION/dig_ascii/$LAYER.old" ]
then
rm $LOCATION/dig_ascii/$LAYER.old
fi
echo -n "..."
# Convert old zone lat/long ASCII data to new zone UTM dig_ascii data.
# The lat/long data is imported back into UTM using the new zone, so
# this is where the zone transformation occurs for the vector data.
m.ll2u -rz spheroid=clark66 zone=$NEWZONE input=$LOCATION/dig_ascii/$LAYER.ll output=$LOCATION/dig_ascii/$LAYER.shift
if [ $? -ne 0 ]
then
echo ""
echo "Problem using m.ll2u for layer $LAYER"
echo ""
exit
fi
echo -n "..."
if [ -f "$LOCATION/dig_ascii/$LAYER.ll" ]
then
rm $LOCATION/dig_ascii/$LAYER.ll
fi
echo -n "..."
# Convert new zone UTM dig_ascii data to new zone binary dig data
v.in.ascii input=$LAYER.shift output=$LAYER.shift
if [ $? -ne 0 ]
then
echo ""
echo "Problem using v.in.ascii for layer $LAYER.shift"
echo ""
exit
fi
echo -n "..."
if [ -f "$LOCATION/dig_ascii/$LAYER.shift" ]
then
rm $LOCATION/dig_ascii/$LAYER.shift
fi
echo -n "..."
# Convert dig_att data to new zone
# The old dig_att file is rearranged using AWK so that the GRASS commands
# m.u2ll and m.ll2u will work properly and still preserve all the needed
# data in the file. AWK is used again to rearrange the results into the
# correct dig_att form. The variable $mapset is set by g.findfile and
# eval earlier in the script.
if [ -f "$LOCATION/../$mapset/dig_att/$LAYER" ]
then
cat $LOCATION/../$mapset/dig_att/$LAYER | awk '{ printf "%14s %14s %11s %1s\n", $2, $3, $4, $1 }' | m.u2ll sph=clark66 zone=$OLDZONE | m.ll2u -z sph=clark66 zone=$NEWZONE | awk '{ printf "%1s %14s %14s %11s\n", $4, $1, $2, $3 }' > $LOCATION/dig_att/$LAYER.shift
else
echo ""
echo "WARNING: no attribute data for $LAYER"
echo ""
fi
# Copy dig_cats data to new name
if [ -f "$LOCATION/../$mapset/dig_cats/$LAYER" ]
then
if [ ! -d "$LOCATION/dig_cats" ]
then
mkdir $LOCATION/dig_cats
fi
cp $LOCATION/../$mapset/dig_cats/$LAYER $LOCATION/dig_cats/$LAYER.shift
fi
# Run v.support for the newly transformed data layer
v.support -r map=$LAYER.shift option=build
fi
done
