Note: original was to grassu-list.
There's a good one included in s.perturb, located at:
ftp://pasture.ecn.purdue.edu/pub/mccauley/grass/.
Contact the original author, W. P. Petersen,
<wpp@ips.ethz.ch> for more details.
Here's a blurb from a README file:
README for zufall random number package, C version
[NOTE: I have not done extension testing of this port.
use at your own risk. The output of the original
FORTRAN program is in zufall.orig.output. The
original FORTRAN source is at
netlib.att.com:netlib/random/zufall.f.Z --jdm]
This package contains a portable random number generator set
for: uniform (u in [0,1)), normal (<g> = 0, <g^2> = 1), and
Poisson distributions. The basic module, the uniform generator,
uses a lagged Fibonacci series generator:
t = u[n-273] + u[n-607]
u[n] = t - (float) ((int) t)
where each number generated, u[k], is floating point. Since
the numbers are floating point, the left end boundary of the
range contains zero. This package was ported from FORTRAN
to K&R C.
--Darrell
tim glover (tim_glover@abbsmtp.abb.com) writes on 15 December 1995:
Sorry this is a little off subject, but I hope someone can help me...
I need source code or algorithm for a good random number generator.
I'm working in an old FORTRAN compiler that doesn't have an
intrinsic one, and I found out that the one I'm using cycles after
about 9000 numbers. Not good enough!
Thanks for any help....
Views expressed above are my own unless otherwise stated
Tim Glover (Tim_Glover@ABBSMTP.abb.com)
ABB Environmental Services
Tallahassee, FL, USA 32301 (904) 656-1293 ext 290
Darrell McCauley, PhD; mccauley@mcs.com; http://www.mcs.com/~mccauley/
