need help with PS.MAP....
Mary;
  Firstly, is your printer on a network? And if so do you manually
send your output to the printer. (this is my situation)
  Second, try playing with the location of the colortable as a
start, I have found that if the colortable is overlapping with the map
image because of placement, my printer experiences the same problem. The
same is often true for text.
Craig
caa@noaacrd.colorado.edu
