Hi John,
I need to correct the below. Under the location, make a PERMANENT mapset,
then untar at this level. Rick
A file "US_lazea.tar.gz" is available on the cast ftp site: cast.uark.edu .
Directory: /data/ftp/private/outgoing/US.lazea
You can make a location direction and untar the file from that directory. Al
l
necessary info (DEFAULT_WIND, etc.) is included. The projection is Lambert
Azimuthal Equal Area.
