Network of SUN cpu's and GRASS
Simon Cox gave good advice on the remote execution of GRASS using
X-window access between a single "GRASS server" machine and various
remote machines. We have a similar setup and use that approach all
the time. We do this both with remote Suns and remote Nexts (using
the Next coXist X emulator) going to a single Sun "GRASS server" over
a thinnet. However, as we found out the hard way, each user must
login to a separate account on the "GRASS server" machine to avoid
contention for the x0 monitor. To be GRASS functional each account
must have a path (in $PATH) set to the grass binary directory (for
example: set path = /home/CGEF/grass/4.0/bin). One drawback to this
approach is that it causes all GRASS processes to be executed on the
"GRASS server" machine. This has obvious negative performance
implications if several users are using GRASS simultaneously.
We also use another method to access GRASS binaries from that one
"GRASS server" machine, but GRASS runs on the remote machines CPU's.
This is done simply by exporting the GRASS binary directory from the
"GRASS server" to a remote machine. The remote machine of course must
then mount this exported directory. This causes the remote machine
to think that the GRASS binaries are part of its file system and they
are therefore executed locally. NFS of course serves the binary from
the "GRASS server" machine. We have found that this method has the
drawback that exporting can become yet another tedious (and
confusing) system admin task as new machines are added to the
network. To minimize this problem we only export GRASS to one
machine. This machine can then act as a "secondary GRASS server" for
the X-window approach. This balances the user load and system admin
work.
Of course this all means that the GRASS binaries are on one machine
and the network is being used to pass these binaries around as well
as all the GRASS images from the "GRASS servers" to X-window
displays. I suppose network slowdown could eventually result. We
haven't noticed that yet, but we rarely have more than 3 people using
GRASS simultaneously, and our setup is fairly new.
Does anyone see any flaws with what I've presented here? We're still
learning new things every week.
Greg Colello
Carnegie Institution, Department of Plant Biology
Stanford University
gcolello@biosphere.stanford.edu
