Neural Nets
Someone posted a question about neural networks and maps and images. Here's
a list of all existing neural network patents to show you what people are
doing. There is much work in character recognition and neural networks,
a very similar problem to map layer analysis. In fact, one patent lists
200 pages of C code to handle rotationally invariant character analysis.
Greg Aharonian
    The following is my periodic posting of new (or newly encountered)
patents dealing with neural networks. Lines below starting with "!" are
new additions to this file. Comments to explain the titles are enclosed
in brackets [...]. The text of any of these patents can be ordered from
the patent office for $3 in printed form. Also, for $20, I will provide
a machine readable version of the abstract, text, claims and references
for any neural network patent.
Greg Aharonian
Source Translation & Optimization
srctran@world.std.com
617-489-3727
     For a very good article on the legal issues involving neural network
patents, see the article "Intellectual Property Protection for Neural
Networks" by Donald Wenskay, Neural Networks, 3, pp. 229-236, 1990.
     For those interested in applying for a neural network patent, I freely
provide a LaTeX template for a patent application. Please email a request,
and I'll send it to you. Contains most of the boilerplate you need.
     To date, I have yet to see any articles in the trade journals on either
companies signing cross-licensing agreements to share their neural network
patents, or patent infringement lawsuits dealing with neural network patents.
To me, this means that no one is making much money with neural networks (other
than selling software), and that the financial return on acquiring a patent
is less than the cost of applying for and maintaining a patent.
     If anyone hears of either occurrence, please let me know.
                             NEURAL NETWORK PATENTS
                    (patents in reverse chronological order)
                        Copyright 1992 Gregory Aharonian
! 5,136,687 awarded to Gerald Edelman, George Reeke 08/92 395/22
! Categorization automata employing neuronal group selection with reentry
! 5,134,685 awarded to Westinghouse Electric 07/92 395/21
! Neural node, a network and a chaotic annealing optimization method for
! the network
! 5,133,021 awarded to Stephen Grossberg / Boston Univ. 07/92 382/15
! System for self-organization of stable category recognition codes for
! analog input patterns
5,131,073 awarded to Ricoh 07/92 395/27
Neuron unit and neuron unit network
5,131,072 awarded to Fujitsu 07/92 395/24
Neurocomputer with analog signal bus
5,131,071 awarded to Omron Tateisi Electronics 07/92 395/3
Fuzzy inference apparatus
5,131,055 awarded to NASA 07/92 382/33
Auto and hetero-associative memory using a 2D optical logic gate
5,130,944 awarded to Samsung Electronics 07/92 364/766
Divider circuit adopting a neural network architecture to increase division
processing speed and reduce hardware components
5,130,943 awarded to Siemens Aktiengesellschaft 07/92 364/724.19
Method and configuration for improving the dynamic range of an adaptive
recursive network for processing discrete time signals
5,130,936 awarded to Arinc Research 06/92 364/551.01
Method and apparatus for diagnostic testing including a neural network for
determining testing sufficiently
5,130,563 awarded to Washington Research Foundation 07/92 307/201
Optoelectronic sensory neural network
5,129,042 awarded to Samsung Electronics 07/92 395/27
Sorting circuit using neural networks
5,129,041 awarded to Grumman Aerospace 07/92 395/25
Optical neural network processing element with multiple holographic element
interconnects
5,129,040 awarded to Mitsubishi Denki Kabushiki Kaisha 07/92 395/25
Neural network for image processing
5,129,039 awarded to Sony 07/92 395/24
Recurrent neural network with variable size intermediate layer
5,129,038 awarded to Matsushita Electric Industrial 07/92 395/23
Neural network with selective error reduction to increase learning speed
5,129,037 awarded to Digital Equipment Corporation 07/92 395/22
Neural network for performing beta-token partitioning in a Rete network
5,124,918 awarded to Case Western Reserve University 06/92 364/424.02
Neural based autonomous robotic system
5,123,049 awarded to Kabushiki Kaisha Toshiba 06/92 381/43
Pattern recognition apparatus with retrieval reference patterns
5,121,467 awarded to E.I. du Pont de Nemours 06/92 395/11
Neural network / expert system process control expert system and method
5,121,465 awarded to NEC 06/92 395/2
Pattern matching system
5,121,443 awarded to Spectra-Physics 06/92 382/29
Neural network system for analyzing chromatographic peaks
5,121,228 awarded to Bell Communications Research 06/92 359/7
Holographic learning machine
5,120,996 awarded to Carver Mead/Synaptics 06/92 307/353
Synaptic element and array
5,119,469 awarded to Environmental Research Inst. Mich. 06/92 395/23
Neural network with weight adjustment based on prior history of input signals
5,119,468 awarded to E.I du Pont de Nemours 06/92 395/22
Apparatus and method for controlling a process using a trained parallel
distributed processing network
5,115,492 awarded to General Electric 05/92 395/27
Digital correlators incorporating analog neural network structures operated
on a bit sliced basis
5,113,485 awarded to Hitachi 05/92 395/25
Optical neural network system
5,113,484 awarded to Samsung 05/92 395/24
Rank filter using neural network
5,113,483 awarded to Microelectronics & Computer Tech. 05/92 395/23
Neural network with semi-localized nonlinear mapping of the input space
5,113,482 awarded to IBM 05/92 395/23
Neural network model for reaching a goal state
5,113,367 awarded to the U.S. Navy 05/92 364/819
Cross entropy deconvolver circuit adaptable to changing convolution functions
5,111,531 awarded to Automation Technology 05/92 395/23
Process control system using neural network
5,109,475 awarded to Hitachi 04/92 395/22
Method and a system for selection of time series
! 5,109,351 awarded to Texas Instruments 04/92 395/24
! Learning device and method
! 5,109,275 awarded to Matsushita Electric Industrial 04/92 358/80
! Printing signal correction and printer operation control utilizing neural
! network
5,107,454 awarded to Agency Ind. Science & Tech-Tokyo 04/92 395/24
Pattern associative memory system
5,107,442 awarded to Recognition Equipment 04/92 395/11
Adaptive neural network image processing system
5,105,468 awarded to ATT Bell Laboratories 04/92 382/14
Time delay neural network for printed and cursive handwritten character
recognition
5,103,496 awarded to US Navy 04/92 395/24
Artificial neural network system for memory modification
! 5,103,488 awarded to Centro Studie E Labor. Telecomm. 04/92 382/22
! Method of and device for moving image contour recognition
! 5,103,431 awarded to GTE Government Systems 04/92 367/135
! Apparatus for detecting sonar signals embedded in noise
5,103,405 awarded to Westinghouse 04/92 395/10
Digital probabilistic reasoning element
5,101,361 awarded to NASA 04/92 395/24
Analog hardware for delta-backpropagation neural network
! 5,099,428 awarded to Nissan Motor 03/92 364/424.1
! Shifting control system for automotive automatic power transmission with
! neuron computer with refined data sampling and shifting pattern recollection
! characteristics
! 5,099,434 awarded to Northrup 03/92 395/25
! Continuous-time optical neural network
5,097,141 awarded to Motorola 03/92 307/201
Simple distance neuron
5,095,459 awarded to Mitsubishi Denki Kabushiki Kaisha 03/92 395/25
5,095,443 awarded to Ricoh 03/92 395/11
Plural neural network system having a successive approximation learning method
5,093,900 awarded to ATT Bell Laboratories 03/92 395/24
Reconfigurable neural network
5,093,899 awarded to Sony Corporation 03/92 395/23
Neural network with normalized learning constant for high-speed stable learning
! 5,093,792 awarded to Kabushiki Kaisha Toyota Chuo 03/92 364/413.01
! Combustion prediction and discrimination apparatus for an internal combustion
! engine and control apparatus therefor
5,092,343 awarded to Wayne State University 03/92 128/733
Waveform analysis apparatus and method using neural network techniques
5,091,864 awarded to Hitachi 02/92 395/27
Systolic processor elements for a neural network
5,091,843 awarded to Allied-Signal 02/92 364/150
Nonlinear multivariable control system
5,087,826 awarded to Intel Corporation 02/92 307/201
Multi-layer neural network employing multiplexed output neurons
5,086,479 awarded to Hitachi 02/92 382/14
Information processing system using neural network learning function
5,086,405 awarded to Samsung Electronics 02/92 364-748
Floating point adder circuit using neural network
5,083,285 awarded to Toshiba 01/92 395/24
Matrix-structured neural network with learning circuitry
5,083,044 awarded to Carver Mead/Synaptics 01/92 307/311
5,080,464 awarded to Hamamatsu Photonics 01/92 359/559
Optical neural network apparatus using primary processing
5,078,952 awarded to Science Applications Inter. Corp 01/92 376/159
Multi-sensor explosive detection system
5,077,677 awarded to Westinghouse Electric 12/91 395/10
Probabilistic inference gate
5,075,889 awarded to Philips Corporation 12/91 365/73
Arrangement of data cells and neural network system utilizing such an
arrangement
5,075,871 awarded to Recognition Equipment Inc. 12/91 395/24
Variable gain neural network image processing system
5,075,869 awarded to Intel Corporation 12/91 395/24
Neural network exhibiting improved tolerance to temperate and power supply
5,075,868 awarded to the US Navy 12/91 395/23
Memory modification of artificial neural networks
5,073,867 awarded to Westinghouse Electric 12/91 395/27
Digital neural network processing elements
5,072,130 awarded to Vernon Dobson 12/91 307/201
Associative network and signal handling element therefor for processing data
5,071,231 awarded to the US Air Force 12/91 359/53
Bidirectional spatial lightl modulator for neural network computer
5,070,480 awarded to John Caywood 12/91 365/49
Nonvolatile associative memory system
5,068,801 awarded to Teledyne Industries 11/91 395/25
Optical interconnector and highly interconnected, learning neural network
incorporating optical interconnector therein
5,068,662 awarded to Louisiana State University 11/91 341/161
Neural network analog-to-digital converter
5,067,095 awarded to Motorola 11/91 395/24
Spann sequence processing artificial neural network
5,065,339 awarded to I.B.M. 11/91 395/24
Orthogonal row-column neural processor
5,065,040 awarded to Motorola 11/91 307/201
Reverse flow neuron
5,063,601 awarded to John Hayduk 11/91 382/14
Fast-learning neural network system for adaptive pattern recognition
apparatus
5,063,531 awarded to NEC Corporation 11/91 395/25
Optical neural network trainable in rapid time
5,063,521 awarded to Motorola 11/91 395/27
Neuram neural network with RAM
5,063,492 awarded to Hitachi 11/91 364/167.01
Motion control apparatus with function to self-form a series of motions
5,061,866 awarded to Ohio State University 10/91 307/529
Analog, continuous time vector scalar multiplier circuits and programmable
feedback neural network using them
5,060,278 awarded to Ricoh Company 10/91 382/14
Pattern recognition apparatus using a neural network system
5,060,276 awarded to ATT Bell Laboratories 10/91 382/8
Technique for object orientation detection using a feed-forward neural
network
5,059,814 awarded to Carver Mead/ Calif. Inst. Tech. 10/91 301/201
Winner-take-all circuits for neural computing systems
5,058,184 awarded to Nippon Hoso Kyokai 10/91 382/37
Hierarchical information processing system
5,058,180 awarded to National Semiconductor 10/91 382/14
Neural network apparatus and method for pattern prediction
5,058,034 awarded to Westinghouse Electric 10/91 395/27
Digital neural network with discrete point rule space
5,056,897 awarded to Matsushita Electric Industrial 10/91 359/72
Spatial light modulating element and neural network circuit
5,056,039 awarded to John Caufield/ Univ. Alabama 10/91 395/25
Holographic interconnect system
5,056,037 awarded to NASA 10/91 395/24
Analog hardware for learning neural methods
5,055,897 awarded to Intel Corporation 10/91 357/23.5
Semiconductor cell for neural network and the like
5,054,094 awarded to Eastman Kodak 10/91 382/18
Rotationally impervious feature extraction for optical character
recognition
5,053,974 awarded to Texas Instruments 10/91 395/27
Closeness code and method
5,052,043 awarded to Eastman Kodak 09/91 382/14
Neural network with back propagation controlled through an output
confidence measure
5,050,096 awarded to Northrop 09/91 395/22
Path cost computing neural network
5,050,095 awarded to Honeywell 09/91 395/23
Neural network auto-associative memory with two rules for varying
the weights
5,048,100 awarded to Michael Kuperstein 09/91 382/36
Self organizing neural network method and system for general classification
of patterns
5,048,097 awarded to Eastman Kodak 09/91 382/14
Optical character recognition neural network system for machine
printed characters
5,047,655 awarded to Thomson-CSF 09/91 307/201
Programmable analog neural network
5,046,020 awarded to E.I. du Pont de Nemours 09/91 395/23
Distributed parallel processing network wherein the connection weights
are generated using stiff differential equations
5,046,019 awarded to Chip Supply Inc. 09/91 395/3
Fuzzy data comparator with neural network postprocessor
5,045,713 awarded to Kabushiki Kaisha Toshiba 09/91 301/301
Multi-feedback circuit apparatus
5,043,913 awarded to Mitsubishi Denki Kabushiki Kaisha 08/91 395/27
Neural network [using synaptic circuits]
5,041,976 awarded to Ford Motor Company 08/91 364/424.03
Diagnostic system using pattern recognition for electronic automotive control
systems
5,041,916 awarded to Matsushita Electric Industrial 08/91 358/433
Color image data compression and recovery apparatus based on neural networks
5,040,230 awarded to Ezel Incorporated 08/91 382/15
Associative pattern conversion system and adaptation method thereof
5,040,215 awarded to Hitachi 08/91 381/43
Speech recognition apparatus using neural network and fuzzy logic
5,040,214 awarded to Stephen Grossberg / Boston Univ. 08/91 381/43
Pattern learning and recognition apparatus in a computer system
5,040,134 awarded to Intel Corporation 08/91 395/27
Neural network employing leveled summing scheme with blocked array
! 5,039,871 awarded to General Electric 08/91 307/201
! Capacitive structures for weighted summation as used in neural nets
5,034,918 awarded to Samsung Electronics 07/91 365/49
Adaptive associative memory comprising synapses of CMOS transistors
5,033,020 awarded to Grumman Aerospace 07/91 364/807
Optically controlled information processing system
5,033,006 awarded to Sharp Kabushiki Kaisha 07/91 395/23
Self-extending neural-network [using multilayers]
5,027,182 awarded to NASA 06/91 357/46
High-gain ALGAAS/GAAS double heterojunction darlington phototransistors for
optical neural networks
5,025,282 awarded to Fuji Photo Film 06/91 355/38
Color image forming apparatus [using neural network for learning image
conditions]
5,023,833 awarded to Baum & Wilczek / Cal. Inst. Tech. 06/91 365/49
Feed forward neural network for unary associative memory
5,023,045 awarded to Doryo Kuro Kakunenryo Kaihatsu 06/91 376/215
Plant malfunction diagnostic method [using neural networks]
5,021,988 awarded to Mitsubishi Denki Kabushiki Kaisha 06/91 395/24
Semiconductor neural network and method of driving the same
5,016,211 awarded to Samsung Electronics 05/91 364/786
Neural network implementation of a binary adder
5,016,188 awarded to Rockwell International 05/91 395/22
Discrete-time optimal control by neural network
5,014,219 awarded to James White 05/91 395/23
Mask controled neural networks
5,014,096 awarded to Matsushita Electric Industrial 05/91 357/19
Optoelectronic integrated circuit with optical gate device and phototransistor
5,010,512 awarded to International Business Machines 04/91 395/24
Neural network having an associative memory that learns by example
5,008,833 awarded to California Institute of Tech. 04/91 395/25
Parallel optoelectronic neural network processors
5,005,206 awarded to U.S. Philips 04/91 382/56
Method of and arrangement for image data compression by means of a neural
network
5,004,932 awarded to Hitachi 04/91 307/201
Unit circuit for constructing a neural network and a semiconductor integrated
circuit having the same
5,004,309 awarded to John Caulfield/Teledyne Brown Eng. 04/91 359/1
Neural processor with holographic optical paths and nonlinear
5,003,490 awarded to Hughes Aircraft 03/91 395/22
Neural network signal processor
5,001,631 awarded to Hughes Aircraft 03/91 364/402
Cellular network assignment processor using randomly triggered adaptive
cell thresholds
4,999,525 awarded to Intel Corporation 3/91 307/201
Exclusive-OR cell for pattern matching employing floating gate devices
4,996,648 awarded to Alexander Jourjine 2/91 395/25
Neural network using random binary code
4,995,088 awarded to Nabil Farhat / Univ. of Penn. 2/91 395/25
Super resolution [for radar using hebbian neural network]
4,994,982 awarded to U.S. Philips 2/91 395/27
Neural network system and circuit for use therein
4,994,927 awarded to GTE Laboratories 2/91 358/426
Self adaptive neural net based vector quantizer for image compression
4,990,838 awarded to ATR Auditory & Visual Perception 2/91 395/81
Movement trajectory generating method of a dynamical system
4,989,256 awarded to Bruce Buckley 01/91 395/27
Self-organizing Circuits
4,988,891 awarded to Mitsubishi 01/91 395/25
Semiconductor Neural Network including Photosensitive Coupling Elements
4,983,962 awarded to Daniel Hammerstrom 01/91 340/825.02
Neural-model, Computational Architecture Employing Broadcast Hierarchy
and Hypergrid, Point-to-Point Communication
4,979,126 awarded to AI Ware 12/90 395/24
Neural network with non-linear transformations
4,979,124 awarded to Cornell Research Foundation 12/90 354/432
Adaptive, neural-based signal processor
4,978,990 awarded to Olympus Cameras 12/90 354/432
Exposure control apparatus for camera [using neural networks]
4,975,961 awarded to NEC 12/90 381/43
Multi-layer neural network to which dynamic programming techniques are
applicable
4,974,169 awarded to Grumman Aerospace 11/90 395/24
Neural network with memory cycling
4,972,473 awarded to Hitachi 11/90 380/20
Data communication method and apparatus using neural-networks
4,972,363 awarded to Boeing 11/90 364/807
Neural network using stochastic processing
4,972,187 awarded to Digital Equipment Corporation 11/90 341/95
Numeric encoding method and apparatus for neural networks
4,970,819 awarded to V/GER 11/90 42/70.01
Firearm safety system and method [for grip recognition using neural nets]
4,965,725 awarded to Neuromedical Systems 10/90 364/413.1
Neural network based automated cytological specimen classification system
and method
4,965,443 awarded to Olympus Optical 10/90 250/201.7
Focus detection apparatus using neural network means
4,963,725 awarded to Rockwell International 10/90 250/201.9
Adaptive optical neural network [using holograms]
4,962,342 awarded to Synaptics 10/90 307/201
Dynamic synapse for neural network [using MOS transistors]
4,961,005 awarded to Michigan State University 10/90 307/201
Programmable neural circuit implementable in CMOS very large scale integration
4,961,002 awarded to Intel Corporation 10/90 307/201
Synapse cell employing dual gate transistor structure
4,959,532 awarded to Hughes Aircraft 09/90 250/201.9
Optical neural network and method [using phase conjugate mirrors]
4,958,939 awarded to Honeywell 09/90 382/35
Centering scheme for pattern recognition [in cameras]
4,956,564 awarded to Intel Corporation 09/90 307/201
Adaptive synapse cell providing both excitatory and inhibitory connections
in an associative matrix
4,954,963 awarded to Texas Instruments 09/90 395/23
Neural network and system [for target recognition]
4,953,099 awarded to M.I.T. 08/90 395/24
Information discrimination cell
4,951,239 awarded to the United States Navy 08/90 364/807
Artificial neural network implementation
4,950,917 awarded to Intel Corporation 08/90 307/201
Semiconductor cell for neural network employing a four-quadrant multiplier
4,947,482 awarded to West Virginia University 08/90 364/807
State analog neural network and method of implementing same
4,945,494 awarded to Texas Instruments 07/90 395/23
4,943,931 awarded to M.I.T. 07/90 395/27
Digital artificial neural processor
4,943,556 awarded to Harold Szu / United States Navy 07/90 505/1
Superconducting neural network computer and sensor array
4,941,122 awarded to Recognition Equipment 07/90 364/807
Neural network image processing system [for target recognition]
4,937,872 awarded to John Hopfield / ATT 06/90 381/43
Neural computation by time concentration
4,933,871 awarded to Duane DiSieno 06/90 395/23
Graded learning device and method
4,931,763 awarded to California Institute of Tech. 06/90 338/22SD
Memory switches based on metal oxide thin films
4,931,674 awarded to United States Navy 06/90 307/529
Programmable analog voltage multiplier circuit means
4,926,180 awarded to Columbia University 05/90 341/159
Analog to digital conversion using correlated quantization and collective
optimization
4,926,064 awarded to Syntonic Systems 05/90 307/201
Sleep refreshed memory for neural network
4,918,618 awarded to Analog Intelligence Corp 04/90 395/21
Discrete weight neural network
4,918,617 awarded to Oregon Graduate Center 04/90 395/21
Neural-model computational system with multi-directionally overlapping
broadcast regions
4,914,708 awarded to Stephen Grossberg/ Boston Univ. 04/90 382/14
4,914,603 awarded to GTE Laboratories 04/90 395/23
Training neural networks
4,912,655 awarded to GTE Laboratories 03/90 395/23
Adjusting neural networks
4,912,654 awarded to GTE Laboratories 03/90 395/23
Neural networks learning method
4,912,653 awarded to GTE Laboratories 03/90 395/26
Trainable neural network
4,912,652 awarded to GTE Laboratories 03/90 395/23
Fast neural network training
4,912,651 awarded to GTE Laboratories 03/90 395/23
Speeding learning in neural networks
4,912,649 awarded to GTE Laboratories 03/90 395/23
Accelerating learning in neural networks
4,912,647 awarded to GTE Laboratories 03/90 395/26
Neural network training tool
4,906,865 awarded to Intel 02/90 307/353
Sample and hold circuit for temporal associations in a neural network
4,904,882 awarded to United States Navy 02/90 307/245
Superconducting optical switch
4,904,881 awarded to Intel 02/90 307/201
Exclusive-OR cell for neural network and the like
4,901,271 awarded to ATT Bell Laboratories 02/90 395/27
Computational network
4,897,811 awarded to Nestor 01/90 395/21
N-Dimensional coulomb neural network which provides for cumulative learning of
internal representations
4,896,053 awarded to Robert Kesselring 01/90 307/201
Solitary wave circuit for neural network emulation
4,893,255 awarded to Analog Intelligence Corporation 01/90 395/24
Spike transmission for neural networks
4,891,782 awarded to United States Army 01/90 364/786
Parallel neural network for a full binary adder
4,885,757 awarded to Texas Instruments 12/89 375/96
Digital adaptive receiver employing maximum-likelihood sequence estimation
4,884,216 awarded to Michael Kuperstein 11/89 395/94
Neural network system for adaptive sensory-motor coordination of multijoint
robots for single postures
4,876,731 awarded to NYNEX 10/89 382/40
Neural network model in pattern recognition using probabilistic contextual
information
4,874,963 awarded to Bell Communications Research 10/89 307/201
Neuromorphic learning methods
4,873,455 awarded to Thomson-CSF 10/89 307/201
Programmable ferroelectric polymer neural network
4,866,645 awarded to North American Philips 09/89 364/602
Neural network with dynamic refresh capability
4,858,147 awarded to Unisys 08/89 395/27
Special purpose neurocomputer system for solving optimization problems
4,849,940 awarded to Washington Technology Center 07/89 365/215
Optical neural network memory
4,837,843 awarded to Hughes Aircraft 06/89 382/31
Hybrid optical and electronic associative memory
4,809,193 awarded to Alexander Jourjine 02/89 395/25
Microprocessor assemblies forming adaptive neural network
4,807,168 awarded to N.A.S.A. 02/89 395/27
Hybrid analog-digital associative neural network
4,804,250 awarded to U.S. Army 02/89 359/36
Optical processor for an adaptive pattern classifier
4,803,736 awarded to Stephen Grosseberg / Boston Univ. 02/89 382/22
Neural networks for machine vision
4,802,103 awarded to Synaptics 01/89 395/24
Brain learning and recognition emulation circuitry and method of
4,782,460 awarded to ATT Bell Laboratories 11/88 395/24
Computing apparatus comprising a programmable resistor
4,782,459 awarded to British Telecommunications 11/88
Adaptive recognizing device
4,773,024 awarded to Synaptics 09/88 395/20
Brain emulation circuit with reduced confusion
4,760,437 awarded to ATT Bell Laboratories 07/88 357/30
Neural networks
4,752,906 awarded to ATT Bell Laboratories 06/88 395/24
Temporal sequences with neural networks
4,737,929 awarded to ATT Bell Laboratories 04/88 395/27
Highly parallel computation network employing a binary-valued T matrix
and single output amplifiers
4,731,747 awarded to ATT Bell Laboratories 03/88 395/24
Highly parallel computation network with normalized speed of response
4,730,259 awarded to Stephen Gallant 03/88 395/22
Matrix controlled expert system producible from examples
4,518,866 awarded to Psychologics 05/85 307/201
Method of and circuit for simulating neurons
4,326,259 awarded to Leon Cooper / Nestor Inc. 05/85 364/715.11
Self organizing general pattern class seperator and detector
4,254,474 awarded to Leon Cooper / Nestor Inc. 03/81 395/27
Information processing system using threshhold passive modification
4,044,243 awarded to Leon Cooper / Nestor Inc. 08/77 395/20
3,950,733 awarded to Leon Cooper / Nestor Inc. 04/76 395/24
3,934,231 awarded to Dendric Decisions 01/76 395/20
Adaptive boolean logic element
3,717,773 awarded to Wisconsin Alumni Research 02/73 307/201
Neuristor transmission line for actively propagating pulses
3,691,400 awarded to LTV Aerospace 09/72 307/201
Unijunction transistor artificial neuron
3,638,196 awarded to Matsushita Electric Industrial 01/72 395/275
Learning machine
3,613,084 awarded to Bell Telephone Laboratories 10/71 395/27
Trainable digital apparatus
3,601,811 awarded to Matsushita Electric Industrial 08/71 395/27
Learning machine
3,599,009 awarded to Wisconsin Alumni Research 08/71 307/201
Neuristor transmission line, learning junction, and artificial neuron
3,597,625 awarded to Nippon Electric Company 08/71 307/41
Neuristor element employing bulk effect semiconductor devices
! 3,594,559 awarded to Philips Petroleum 07/71 235/151.12
! Process control for polymerization control system having equation updating
! feedback networks
! 3,591,778 awarded to Adaptronics 07/71 235/150.1
! Self-organizing control system with constrained performance assessment
3,566,359 awarded to Melpar Inc. 02/71 395/20
Trainable computer module
3,562,502 awarded to Stanford Research Institute 02/71 395/27
Cellular threshold array for providing outputs representing a complex
weighting functions of inputs
3,546,601 awarded to U.S. Navy 12/70 328/116
Neuronal event recognizer
3,535,693 awarded to Melpar Inc. 10/70 395/20
Trainable logical element having signal path solidification capabilities
3,533,072 awarded to I.B.M. 10/70 395/24
Adaptive logic system utilizing modification of output feedback in
conditioning control loop
3,496,382 awarded to Aerojet General 02/70 307/201
Learning computer element
3,476,954 awarded to RCA Corporation 11/69 307/201
Electrical neuron circuit that includes an operational amplifier
3,453,602 awarded to Aerojet General 07/69 365/153
Electrochemical signal processing and storage device
3,435,422 awarded to Bell Aerospace 03/69 395/575
Self organizing system
3,430,203 awarded to Texas Instruments 02/69 395/24
Trainable decision system utilizing metal-oxide-semiconductor fielf effect
transistors
H000632 awarded to /89 359/107
Optical neuromorphic embodiments of self-regulating neural networks
