Dear GRASS community,
Pierre asked me to announce his latest
improvements:
On Tue, Apr 25, 2000 at 04:23:05PM +0200, Pierre de Mouveaux wrote:
- r.line: working now with Grass5.0
- r.drain: corrected lat-lon projection issues, sites lists accepted
on input, and 3 selectable output modes:
- all lines '1's
- input value copied along path and
- cumulated input values copied along path
- r.cost with sites files accepted as start points and stop points.
- d.vect that runs quitely by default (flag -v added), so no popup
that jumps in tcltkgrass.
The "INFINITY" problem in r.cost is fixed as well, the r.binfer problem,
too (hopefully).
David D Gray updated the v.in.shape: generates vector maps in
arc-node mode now, so it should run much better than the common
v.in.shape module.
These changes are uploaded to CVS and will appear in the
GRASS 5 beta 8. Perhaps we can provide a small source update
package soon.
Best regards
Markus Neteler
