New GRASS 4.2.1 package
Hi, 30.1.98
just now I have uploaded to
http://www.laum.uni-hannover.de/iln/grass/grass42/
     - a new GRASS binary package (Version 4, new ps.map etc.)
     - new source code package (version 6)
     - separated documentation package
Have fun
     Markus Neteler
                           Department of Geography
                   Institute of Physical Geography and
                           Landscape ecology
                     University of Hannover, Germany
                   email: neteler@geog.uni-hannover.de
       Homepage: Bereich Geographie – Naturwissenschaftliche Fakultät – Leibniz Universität Hannover
Hello Grass Users!
  I'm trying to compile Mapgen 6.25 using the source code from Markus
Neteler's site (many, many thanks, Markus!).
  Main Grass binaries I've installed (from Markus... Thanks again.) are
working fine and smooth. I let them all at /usr/local/grass42 for the
sake of simplicity (no further edits, no further checkings).
  I downloaded the source code and gunziped & untared it under this all
common and plain vanilla tree.
  All the links to libraries are OK, I copied gmake4.2 to /usr/local/bin,
symlinked gzcat to zcat. I wish everything is quite the same I've
encountered on the documents from Markus.
  Then I changed to /usr/local/grass42/src421/src.related/mapgen_625 and
try a 'gmake4.2'.
  I got that scrolled down message:
SRC = /usr/local/grass42/src421/src
  CMD = /usr/local/grass42/src421/src/CMD
  HEADER = linux
  ARCH = linux
  GISBASE = /usr/local/grass42
  VERSION = 4.2.1 V.14 - April 1998
/usr/local/grass42/src421/src.related/mapgen_6.25
  make -f OBJ.linux/make.rules
/usr/local/grass42/src421/gmake4.2 setup
  HEADER = linux
  ARCH = linux
/usr/local/grass42/src421/src.related/mapgen_6.25/setup
make[1]: Entering directory `/usr/local/grass42/src421/src.related/mapgen_6.25/setup'
MGGEN.sh /usr/local/grass42
make[1]: Leaving directory `/usr/local/grass42/src421/src.related/mapgen_6.25/setup'
make [1]: MGGEN.sh: Command not found
make [1]: *** [all] Error 127
make: [all] Error 2
  I read a litle the scripts itself and noted the commands pointed to
.../mapgen4.0. Then I changed again to /usr/local/grass42/.../mapgen4.0
and fired another 'gmake4.2'. Now I got a longer message but no
succesful compiling yet"
  HEADER = linux
  ARCH = linux
/usr/local/grass42/src421/src.related/mapgen_6.25/mapgen4.0
/usr/local/bin/gmake4.2 lib/src
  HEADER = linux
  ARCH = linux
/usr/local/grass42/src421/src.related/mapgen_6.25/mapgen4.0/lib/src
make[1]: Entering directory `/usr/local/grass42/src421/src.related/mapgen_6.25/mapgen4.0/lib/src'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/usr/local/grass42/src421/src.related/mapgen_6.25/mapgen4.0/lib/src'
/usr/local/bin/gmake4.2 src
  HEADER = linux
  ARCH = linux
/usr/local/grass42/src421/src.related/mapgen_6.25/mapgen4.0/src
make[1]: Entering directory `/usr/local/grass42/src421/src.related/mapgen_6.25/mapgen4.0/src'
gcc -Wl -s -o /usr/local/grass42/mapgen/bin/legend OBJ.linux/legend.o ../../lib/LIB.linux/libgen.a ../../lib/LIB.linux/libgraph.a -lm
make[1]: Leaving directory `/usr/local/grass42/src421/src.related/mapgen_6.25/mapgen4.0/src'
gcc : .../../lib/LIB.linux/libgraph.a: No such file or directory
make [1]: ***[/usr/local/grass42/mapgen/bin/legend] Error 1
make: *** [all] Error 2
  A couple of questions:
  What is that 'libgraph.a' I've not found in my disk? (I'm using Debian
1.3 R3 and gcc 2.7.2.1)
  Does anyone find what's going wrong? (being more precise: what am I
doing wrong?)
  Many thanks,
Adalberto da Silva
Instituto Astronomico e Geofisico - USP
Sao Paulo - Brasil
adalbert@iag.usp.br
HI.. all
I've got following error in d.mon. What does it mean and how can I get
over this? When I input d.mon command in grass4.2 prompt, I always got
this error. Please help me.. I use solaris2.5.1 on sparcstation.
raphics driver [x0] started
Error - Could not complete locking process for monitor <x0>.
Lock file is /home/grass/locks/dola/mon.233579
Problem selecting x0. Will try once more
Shin, Sanghee
Environment Design & Theory Lab.
Seoul National University
mailto:endofcap@dola.snu.ac.kr
http://dola.snu.ac.kr/~endofcap
Hello Grass-Users !
Congratulations to the new GRASSBinaries with TCLTKGRASS. That looks
really great. We have recently updated to v16 and TCLTKGRASS20.
After installing and linking the TCLTK-Files, the tcltkgrass started
fine, we could start a graphics monitor, but when we tried to display a
raster or vector map, we got the following error-message:
error in tcl script:
ERROR: bad relief type "solid":
must be flat, groove, raised, ridge or sunken
Anyone had similar problems ?
Anyone has an idea what is going wrong?
We use grass4.2.1v16 under linux slackware, fvwm2.
Thanks, Michael
Michael Schulz
Christoph-Mang-Str.5 Geologisches Institut
79100 Freiburg Universitaet Freiburg
                           Albertstr. 23b
                           79104 Freiburg
On 06-Jun-98 Michael Schulz wrote:
Hello Grass-Users !
Thanks, Michael
Exactly same problems.
RedHat 4.x (very modified and upgraded)
Kernel 2.0.33
Tcl & Tk installed as instructions tell.
Grass working perfectly normal ways.
Thanks also,
Kari
Kari Salovaara
Pitkäkatu 25-29 A 6
FIN-10900 Hanko
Finland
tel. +358 19 2483388
      +358 400 804549
email ecosyd@surfnet.fi
