new host name
CERL systems administrator John Mckeown is moving
the GRASS ftp site is moving to a new machine this afternoon,
and forwards the following note, fyi:
the "moon" ftp site will be moving to a new home later today.
the name will stay the same (moon.cecer.army.mil), the ip address
will change. the old ip address was 129.229.20.254. it will
change to 129.229.103.1. normally, you should simply use the
name (if possible), as that allows us to move this service to
different machines without interruption in service. however,
due to vagarities of the domain naming service, for a short time
some of you will continue to get the old ip address when you
attempt to connect using the name.
my apologies for sending this to this list, but it seemed a
relevant audience and i wanted to reach as many people as was
reasonably possible. thanks.
---- cut here ----
John Mckeown
jrm@uiuc.edu
