NEWBY: r.in.tiff versus Linux
Hello,
I am attempting to import a tiff file using the above command, however when
I initially ran it I got a message saying that it could not locate shared
library libjpeg.so.6. Well in /usr/lib I found libjpeg.so.62.0.0 and
created a link to it called libjpeg.so.6 Then I ran ldconfig. However now
when I run r.in.tiff I get a segmentation violation error.
Any ideas?
Marc Pelletier
Data Donkey - Geophysical Data Processing, Consulting and Software Development
               Creator of the POWER TOOLBOX utilities for OASIS montaj
contact: mailto:marc@datadonkey.com tel (306) 931-6853 or
http://www.datadonkey.com
Well this is strange.
Did you try to compile it yourself?
This might cure the problem.
There also might be a bug in your r.in.tiff version.
It might be a library mismatch.
  Bernhard
ps.: addendum to ps.map:
http://www.geog.uni-hannover.de/grass/gdp/html_421/html/ps.map.html
Research Assistant, Geog Dept UM-Milwaukee, USA. (www.uwm.edu/~bernhard)
Free Software Projects and Consulting (intevation.net)
