I've been using p.map to produce postscript output of a vector
map patched together from USGS DLG hydrography coverages
(ppmtopgm paint.ppm|pgmtops>outfile).
The problem is that stream origins and terminations are
marked by rather prominent nodes on the output, producing a
busy-looking map. Is there any way to suppress these on the output?
Thanks in advance,
bjr
Bret James Ruby Voice: (812) 855-9544
Glenn A. Black Laboratory of Archaeology Fax: (812) 855-1864
9th and Fess Streets Bitnet: bruby@indiana
Bloomington, IN 47405 Internet: bruby@indiana.edu
