NVIZ - image dump
Hi there,
those having problems to use "image dump" in NVIZ
("bad magic number" problem) should know:
You first have to close nviz, *then* open the stored
RGB-image (use xv or anything else). It seems the file
is not closed immediately when storing. Jaro told me about
this way.
Anyone who can fix this?
Markus Neteler wrote:
Hi there,
this way.
It seems taht it's the same when you run a animation : I got this
message, but after a while, images can be opened by xv. I only
tested a 25 images animation : If the images are not closed until
you quit nviz, you may be very limited in animation length !
Michel Wurtz ENGEES - CEREG
                1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
                Tel: +33 03.88.24.82.45 Fax: +33 03.88.37.04.97
