nviz2.2 for GRASS 4.2.1/Linux
Hi there,
if you like to try, get the nviz2.2 precompiled on
Linux/Intel here:
http://www.geog.uni-hannover.de/grass/grass421/linux/
nviz_linuxbin.tar.gz (290k)
Extract the package in
/usr/local/grass42
NVIZ will be started within GRASS by
   nviz2.2
Note: When opening a new map, the map names are
not displayed. This is fixed for the next GRASS 5beta4
release. Take the NVIZ2.2 for GRASS 4.2.1 as a preview,
we will not spend time on that. Further development
will be done in GRASS 5 environment.
You need tcl8.0.x/tk8.0.x and libraries to run NVIZ. Additionally
the openGL clone "MESA" is required.
Tcl/tk8.0: http://www.scriptics.com/products/tcltk/8.0.html
Mesa 3.0: http://www.mesa3d.org/
           http://gd.tuwien.ac.at/graphics/libs/Mesa/
Best regards
  Markus Neteler
Hi Markus, hi all,
so far, so good - but please be aware of some wrong absolute pathnames
e.g. in
  /usr/local/grass42/etc/bin/contrib/cmd/nviz2.2
they refere to
  /usr/local/grass-5.0b/...
and if you don't have grass5.0bX on your box, you have some problems :slight_smile:
Stephan
Stephan Eickschen Tel. : +49 (0)251 83-34704
Westfaelische Wilhelms-Universitaet Fax. : +49 (0)251 83-36100
Institute for Geophysics
Research Unit of Physical Glaciology email: eicksch@uni-muenster.de
Corrensstrasse 24
48149 Muenster
Germany
    http://earth.uni-muenster.de/~eicksch/
it seems to be more "worse": I think that the path
is written to
  ./etc/bin/contrib/cmd/NVWISH2.2
and this is a binary...
I have changed all the script files, but the problem
translating colors
Error in startup script: couldn't read file
"/usr/local/grass-5.0b/etc/nviz2.2/scripts/config.tcl": no su
ch file or directory
    while executing
"source $src_boot/config.tcl"
    (file "/usr/local/grass42/etc/bin/contrib/cmd/nviz2.2" line 12)
did persist, so the last chance were the two binaries, and grep found
it with:
grep grass-5.0b
Binary file ./etc/bin/contrib/cmd/NVWISH2.2 matches
and
hexdump -c ./etc/bin/contrib/cmd/NVWISH2.2 | grep "g r a"
found
00555d0 a l / g r a s s - 5 . 0 b / e t
Is someone willing to compile NVWISH2.2 using
  /usr/local/grass42/(...)
Best wishes,
Stephan
Corrensstrasse 24
48149 Muenster
Germany
