OLD_T_NEW?
Markus Neteler wrote:
> hi.
> what does "SYSTEM_ERROR: OLD_T_NEW Got a bad type code 20" mead
> while using d.vect?
This is a message from
src/libes/vect32/diglib/old2new.c
I guess it is used to convert old GRASS 3.x vectors to
GRASS 4.x/5.x vector format.
Try to run v.support on the map, then d.vect again.
v.support also prints the same errors and Killed.
Huidae Cho
