From grass-lists-owner@moon.cecer.army.mil Fri Feb 23 19:57 eur 1996
X400-Received: by mta nogal.csic in /PRMD=iris/ADMD=400net/C=es/; Relayed; Fr
i,
keep on with problems with this coastlines vector.
Mysteriously, there are closed polygons made up of
edges that are open area lines. Hence, I cannot
label the polygons as areas and get wrong results from
v.cutter.What can I do to convert these open area lines into
closed area lines? I repeat that the polygon is closed,
all nodes are 2-lines nodes.
Agus,
sounds to me like you're having double lines in your file, of
the kind that share the same position but do not share
the nodes. You can check this by going into v.digit, moving
a line of the offending polygon and redraw. Editing however
will not be the greatest of pleasures :). Hope this helps,
Philip Verhagen
philip@raap2.ivambv.uva.nl
R A A P
Plantage Muidergracht 14
1018 TV Amsterdam
The Netherlands
tel: +31 (20) 525 58 35
fax: +31 (20) 525 58 34
http://raap2.ivambv.uva.nl/home_eng.html
