Hi Grasslers!
I want to know, where the origin of the austrian military coordinate system
(OMK) is. If possible in lat/lon or UTM.Thanx in advance
Stephan
Absolutely no idea what system the Austrian army is using, but I suppose
you want to use this information to convert your data to some other
system like lat/long or UTM. You'll obviously need information on:
- projection used
- additional parameters for this projection, like standard parallels
- origin of the coordinate system
When you have this, you can use PROJ to convert it to other systems. Hope
this helps a bit.
Gruess Gott,
Philip Verhagen
S t i c h t i n g R A A P
Regionaal Archeologisch Archiverings Projekt
adress: Plantage Muidergracht 14
1018 TV Amsterdam
THE NETHERLANDS
phone: (31) 20 525 5835
fax: (31) 20 525 5834
e-mail: motte@xs4all.nl
