[OSGeo] #3076: Can not see some services on osgeo3
Reporter: cvvergara | Owner: sac@…
     Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: SysAdmin/DNS | Keywords:
* https://gallery.osgeo.org/ bad gateway
* https://photo.osgeo.org/ welcome to nginx
* https://demo.pygeoapi.osgeo.org/ Error code: SSL_ERROR_BAD_CERT_DOMAIN
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3076&gt;
OSGeo <Gter - OSGeo;
Component: SysAdmin/DNS | Resolution:
Keywords: |
Comment (by robe):
MIght have been my bad cleanup job.
demo.pygeoapi.osgeo.org can be deleted. We had set up an instance for
them to use, but they never used it so just delete that.
photo.osgeo.org you can delete as well, that I think we got rid of cause
we couldn't decide on pixelfed or photoprism.
gallery.osgeo.org I think you can delete as well that is brian's machine
and he only has https://nextcloud.gallery.osgeo.org exposed.
I'm checking on photoprism.osgeo.org which is hosted on osgeo7. That one
does seem to be down.
Ticket URL: <#3076 (Can not see some services on osgeo3) – OSGeo;
Keywords: |
Comment (by robe):
I've ticket the photoprism one at #3077 and working on bringing that back
up.
photo.osgeo.org can be deleted, I don't see it running but do see it in
sites-available, it was associated with pixelfed, which I have just shut
down on osgeo9, with future plan to remove unless someone wants it
revived.
I also noticed looks like nexus container had started up again, I shut
that down, because it is replaced with nexus-2. I just couldn't delete it
cause there was a lock on it so need to reboot osgeo3 before I can delete
it.
Keywords: |
Comment (by robe):
I was able to delete nexus without reboot. It too a while though. I'll
put in another ticket to rename nexus-2 back to nexus and change all the
web configs and backup script back to nexus
