[OSGeo] #3101: Remove spatialreference.org from osgeo7
Reporter: robe | Owner: sac-tickets@…
     Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2024-I
Component: SysAdmin | Keywords:
It appears spatialreference.org has been moved to github. Not sure who
made the pairs DNS change, but was noted here -
Howard Butler: "@jjimenezshaw@mapstodon.space has been kicking co…" - Fosstodon
So I'm going to remove it from osgeo7 and see if I can shut down that old
server. I think that might have been the only thing running on it.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3101&gt;
OSGeo <Gter - OSGeo;
     Type: task | Status: closed
Component: SysAdmin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Ticket URL: <#3101 (Remove spatialreference.org from osgeo7) – OSGeo;
Keywords: |
Comment (by robe):
I also shutdown the old-projects instance as that appears to be the only
thing that was still running on it.
Keywords: |
Comment (by neteler):
Replying to [ticket:3101 robe]:
> Not sure who made the pairs DNS change
Here the details:
[PROJ] spatialreference.org updated!
Maybe we need a procedure who can change OSGeo DNS entries and which steps
are needed.
Keywords: |
Comment (by robe):
Replying to [comment:3 neteler]:
> Here the details:
steps are needed.
I had assumed it was @hobu cause I know he has access to Pairs and sent
the announcement.
Thanks for confirming. My big complaint isn't so much the DNS change as
just not notifying SAC so we could shut off the old services, but maybe he
had intended to later.
Keywords: |
Comment (by hobu):
Indeed it was me who made the DNS change. I wanted to give ourselves a
chance to revert for a day or two in case something bad was found, but
everything can be shut off now on osgeo7.
Thanks for all the efforts to keep that old dog alive.
