[OSGeo] #3110: Add matrix-client.osgeo.org and chat.osgeo.org DNS record
Reporter: strk | Owner: sac-tickets@…
     Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2024-I
Component: SysAdmin/DNS | Keywords:
Needed for the matrix client setup ( #3041 )
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3110&gt;
OSGeo <Gter - OSGeo;
Reporter: strk | Owner: cvvergara
Priority: normal | Milestone: Sysadmin Contract 2024-II
Component: SysAdmin/DNS | Resolution:
Keywords: |
Changes (by robe):
* owner: sac-tickets@… => cvvergara
* milestone: Sysadmin Contract 2024-I => Sysadmin Contract 2024-II
Ticket URL: <#3110 (Add matrix-client.osgeo.org and chat.osgeo.org DNS record) – OSGeo;
Keywords: |
Changes (by strk):
* cc: lnicola (added)
Comment:
And I guess chat => CNAME to matrix-client
Keywords: |
Comment (by robe):
Replying to [comment:4 strk]:
Are you planning to run these on the matrix instance or you are setting up
a separate instance for them. I was thinking if you are going to have it
on the same instance, makes sense to just CNAME them all to
matrix.osgeo.org, that way if we move the container that's the only dns
entry that needs changing.
Keywords: |
Comment (by strk):
I guess we can use the same container, to reduce complexity.
Keywords: |
Comment (by lnicola):
That would probably be blocked on #2988, so my slight preference would be
towards a separate instance.
But Element Web is just a static website, it doesn't need a lot of
resources to run.
Keywords: |
Comment (by cvvergara):
Is this correct?
* Type: CNAME
* Name: matrix-client
* IPv4 address (required): web.osgeo3.osgeo.org
* Proxied or DNS only: DNS only
or
* Name: matrix
Keywords: |
Comment (by robe):
Replying to [comment:8 cvvergara]:
> Is this correct?
> * Type: CNAME
> or
> * Name: matrix
We've already got a matrix.osgeo.org, but the CNAME should be
matrix.osgeo.org since per strk, it is going to run on the matrix instance
So:
  * Type: CNAME
  * IPv4 address (required): matrix.osgeo.org
     Type: task | Status: closed
Component: SysAdmin/DNS | Resolution: fixed
Keywords: |
Changes (by cvvergara):
* status: new => closed
* resolution: => fixed
Comment:
Done
