#3123: Gitea service unavailable (502 Bad Gateway)
Reporter: strk | Owner: strk
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2024-III
Component: SysAdmin/Gitea | Keywords:
OSGeo Git Services: Gitea - Git with a cup of tea is currently anavailable, message says 502
Bad Gateway
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3123>
OSGeo <Gter - OSGeo;
Component: SysAdmin/Gitea | Resolution:
Keywords: |
Comment (by robe):
I restarted gitea with
systemctl restart gitea
and it came back up, but haven't checked the logs why it went down.
It has plenty of disk space which is usually the issue.
Ticket URL: <#3123 (Gitea service unavailable (502 Bad Gateway)) – OSGeo;
Reporter: strk | Owner: robe
Keywords: |
Changes (by strk):
* owner: strk => robe
* milestone: Sysadmin Contract 2024-III => Sysadmin Contract 2024-I
Type: task | Status: closed
Component: SysAdmin/Gitea | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
going to close this out as the service is back up and there is not enough
info in the logs (/var/log/postgresql or /var/log/gitea) to figure out
what was wrong.
@Lnicola is working on ansible gitea role, to properly set it up as a
systemd service which should hopefully provide more info in the future.
