[OSGeo] #3154: Upgrade gitea to 1.21.9
Reporter: robe | Owner: sac-tickets@…
     Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2024-I
Component: SysAdmin | Keywords:
Looks like they've done a lot of work on the act runner which allows
running github actions on gitea self-hosted infra.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3154&gt;
OSGeo <Gter - OSGeo;
Component: SysAdmin | Resolution:
Keywords: |
Comment (by robe):
I upgraded dev.git.osgeo.org/gitea to 1.21.9, but noticing the image when
you log in doesn't show up, gives a 404
https://dev.git.osgeo.org/gitea/assets/img/osgeo-logo.png
It showed up before the upgrade, so need to change if need to make config
changes to the config before upgrading production.
Ticket URL: <#3154 (Upgrade gitea to 1.21.9) – OSGeo;
Keywords: |
Comment (by robe):
login button also has no text
Keywords: |
Comment (by robe):
Even worse two-factor gives an error. Which is odd cause I also tested
1.21.7 (which is what is listed as stable on gitea site) and that at least
did not give a two-factor login error.
Keywords: |
Comment (by robe):
two-factor might be a cache issue, cause switching to chrome where I have
no prior history of this site, two-factor login worked, but still missing
image issue remains.
