[OSGeo] #3213: osgeo8 backup failing
Reporter: robe | Owner: sac-tickets@…
     Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2024-I
Component: SysAdmin | Keywords:
I've been getting errors for the past 2 or so days from osgeo4 that osgeo8
backup is failing.
I'll probably need to reboot osgeo8 to fix.
Planning to do that shortly - so following services will be down hopefully
for no more than 15 minutes to 1 hr.
SAC Service Status - OSGeo
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3213&gt;
OSGeo <Gter - OSGeo;
     Type: task | Status: closed
Component: SysAdmin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Rebooted and running a backup of grasswiki to confirm backup is working.
I'll reopen if still an issue.
Ticket URL: <#3213 (osgeo8 backup failing) – OSGeo;
     Type: task | Status: reopened
Keywords: |
Changes (by robe):
* status: closed => reopened
* resolution: fixed =>
Comment:
The backup of grasswiki did work, but got the error again today.
Error: Failed instance creation: Error transferring instance data: Failed
migration on target: Error reading migration control source: websocket:
close 1000 (normal)
So might be a specific container.
I'll investigate and close this out once resolved.
