#3238: Upgrade Trac to either 1.4.4 or 1.6
Reporter: Mike Taves | Owner: strk
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: SysAdmin/Trac | Keywords:
Currently OSGeo is running and older [Trac · PyPI
Trac 1.4.3] released May 10, 2021, based on Python 2.7.
The web UI shows that this is Python 2, as it has output like
`Branches:[(u'master', ...)]`
According to [TracDownload – The Trac Project TracDownload]
there are two supported release series:
* Older Stable Release - currently [Trac · PyPI
Trac 1.4.4], still uses Python 2.7.
* Latest Stable Release - currently [Trac · PyPI
Trac 1.6], which requires Python 3.
Note that currently 1.6 is supported in Debian bookworm via
[Debian -- Details of package trac in bookworm-backports backports].
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3238>
OSGeo <Gter - OSGeo;
Component: SysAdmin/Trac | Resolution:
Keywords: |
Comment (by strk):
We're still on Debian Buster (10) on that host so this ticket is better
done after a system upgrade (or contextually), see #2822
Ticket URL: <#3238 (Upgrade Trac to either 1.4.4 or 1.6) – OSGeo;
Type: task | Status: assigned
Priority: normal | Milestone: Sysadmin Contract 2024-III (strk)
Component: | Resolution:
SysAdmin/Trac |
Keywords: |
Changes (by strk):
* status: new => assigned
* milestone: Unplanned => Sysadmin Contract 2024-III (strk)
Comment:
Actually it looks like trac is currently installed via pip so we can
easily upgrade to 1.4.4 - I'll check release notes and proceed with the
least risky. We might setup a staging container for 1.6
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3238#comment:2>
SysAdmin/Trac |
Keywords: |
Comment (by strk):
Previous upgrade was from 1.2 to 1.4 and tracked by #2372
A staging host already exists, I've added info about it on
Trac - OSGeo
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3238#comment:3>
Type: task | Status: closed
Component: | Resolution: fixed
SysAdmin/Trac |
Keywords: |
Changes (by strk):
* status: assigned => closed
* resolution: => fixed
Comment:
I've upgraded trac to 1.4.4 on both staging and production, using:
> pip install --upgrade Trac==1.4.4
I'll close this ticket, feel free to file a new one if you see a
compelling reason to upgrade to 1.6
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3238#comment:4>
SysAdmin/Trac |
Keywords: |
Comment (by strk):
Trac 1.6 is in staging (compelling reason was upgrade to Debian Bullseye
forced python3 for mod_python): please test https://dev.trac.osgeo.org
Type: task | Status: reopened
SysAdmin/Trac |
Keywords: |
Changes (by strk):
* status: closed => reopened
* resolution: fixed =>
SysAdmin/Trac |
Keywords: |
Comment (by strk):
One problem we have is that the `{{{ box ` syntax on wiki, as used by
PostGIS start wiki page is not available in current
staging Trac-1.6, it must be implemented by some plugin that are currently
not installing fine, but I don't know which plugin implements that
SysAdmin/Trac |
Keywords: |
Comment (by strk):
It could be one of these plugins, all failing to install:
:stderr: ERROR: Could not find a version that satisfies the
requirement TracDoxygen
requirement TracGamedevTheme
requirement TracpathTheme
requirement TracSectionEditPlugin
requirement TracTweakTheme
requirement BasicThemeEditorPlugin
requirement BlueFlatTheme
SysAdmin/Trac |
Keywords: |
Comment (by strk):
I think "box" is defined by https://trac-hacks.org/wiki/WikiExtrasPlugin
The plugin is installed on the system but for some reason trac doesn't
list it here: https://dev.trac.osgeo.org/postgis/admin/general/plugin
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3238#comment:9>
SysAdmin/Trac |
Keywords: |
Comment (by strk):
The culprit seems to be this:
[2024-08-21 12:10:43,970] postgis:loader ERROR: Skipping "tracwikiextras =
tracwikiextras": ModuleNotFoundError: No module named 'boxes'
More errors are in /var/log/trac_all.log
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3238#comment:10>
SysAdmin/Trac |
Keywords: |
Comment (by strk):
One difference I spotted between the working (1.3.2.dev0) and non-working
(1.3.1) versions of WikiExtrasPlugin is an import line that is more
qualified in the working version:
> dist-packages/tracwikiextras/__init__.py:from tracwikiextras.boxes
import AboutWikiBoxes, Boxes
Whereas in the non-working version is only `from boxes`
Now to find out how to force install of 1.3.2.dev0
SysAdmin/Trac |
Keywords: |
Comment (by strk):
There is no 1.3.2 package on pyPI so 1.3.2.dev0 must have been installed
from a development branch but I cannot find the sources
SysAdmin/Trac |
Keywords: |
Comment (by strk):
Sources found, although they are on a very slow server. Trunk branch has
the fix:
https://trac-
hacks.org/svn/wikiextrasplugin/trunk/tracwikiextras/__init__.py
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3238#comment:13>
SysAdmin/Trac |
Keywords: |
Comment (by strk):
Version 1.3.2.dev0 of TracWikiExtras is now installed (via ansible, from
the svn source repository)
SysAdmin/Trac |
Keywords: |
Changes (by strk):
* status: reopened => closed
Comment:
Trac 1.6 is up and running in production
