#3245: lists.osgeo.org should be using TLS/SSL and DKIM
Reporter: robe | Owner: sac-tickets@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2024-III (strk)
Component: | Keywords:
SysAdmin/Postfix |
Someone on gmail is complaining about getting mails delayed by as much as
a day from geos mailing list.
Looking at the mail logs, it seems we are being dinged on sending plain
text mail. So I suspect any email to an @gmail.com address may be dinged
delayed because of this.
The log shows
Your email has been rate limited because DKIM authentication didn't
421-4.7.30 pass for this message. Gmail requires all bulk email senders to
421-4.7.30 authenticate with DKIM. 421-4.7.30 421-4.7.30
Your email has been rate limited because this message wasn't sent
421-4.7.29 over a TLS connection. Gmail requires all bulk email senders to
use 421-4.7.29 TLS/SSL for SMTP connections
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3245>
OSGeo <Gter - OSGeo;
