#3267: disable mailing list mode
Reporter: jive | Owner: sac-tickets@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: SysAdmin/Discourse | Keywords:
Mailing list mode results in a firehose of email from discourse as
documented here: https://meta.discourse.org/t/what-is-mailing-list-
mode/46008
Which cautions:
> you might set it as default if you want your end users to get regular
notices of all traffic in all categories, by default.
And:
> hilariously, if you’re just “watching” a topic, you’ll get all the
emails, with context, and you won’t get your own posts.
With this in mind I would like to disable the setting, so it is not
available to trip up new users.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3267>
OSGeo <Gter - OSGeo;
#3267: Discourse admin change: disable mailing list mode
Component: SysAdmin/Discourse | Resolution:
Keywords: |
Changes (by jive):
* summary: disable mailing list mode => Discourse admin change: disable
mailing list mode
Ticket URL: <#3267 (Discourse admin change: disable mailing list mode) – OSGeo;
Keywords: |
Comment (by robe):
sounds like a good idea to me. I'd go for it and anyone can complain here
if they have issue.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3267#comment:2>
Type: task | Status: closed
Component: SysAdmin/Discourse | Resolution: fixed
Keywords: |
Changes (by jive):
* resolution: => fixed
* status: new => closed
Comment:
I have disabled mailing list mode and confirmed the option is no longer
visible when reviewing my user email preferences.
I also lots of sensible settings here that would be good to review.
Keywords: |
Comment (by jive):
For anyone who had enabled mailing list mode - they can no longer access
the setting to opt-out!
Indeed the setting only hides the user interface, rather than turn off the
functionality (classic solution to unwanted feature).
To address:
- Use admin settings to re-enable mailing list mode option for everyone
- navigate to their user preferences, email, and and uncheck mailing-list
mode
- return to admin settings to disable mailing list mode again.
