#3272: Serve trac static files as static resources (not involving python)
Reporter: strk | Owner: strk
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: SysAdmin/Trac | Keywords:
See TracInstall – The Trac Project
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3272>
OSGeo <Gter - OSGeo;
Component: SysAdmin/Trac | Resolution:
Keywords: |
Comment (by strk):
I've deployed serving static files without using python on the staging
server and after testing I'm deploying to production.
See the ansible part here:
https://git.osgeo.org/gitea/sac/ansible-
deployment/commit/b7eb20f11552aba3b4a82561ab9a14d61f0d00de
There is a non-ansible part which was done manually before the deploy and
is now documented in Trac - OSGeo
I guess we could make an ansible task for that as well, which should only
run when trac is upgraded or a new plugin is installed.
Ticket URL: <#3272 (Serve trac static files as static resources (not involving python)) – OSGeo;
Keywords: |
Comment (by strk):
Serving static files like this seem to also help with the 502 ( bad
gateway ) responses ticketed in #3271
Type: task | Status: closed
Priority: normal | Milestone: Sysadmin Contract 2024-I
Component: SysAdmin/Trac | Resolution: fixed
Keywords: |
Changes (by strk):
* milestone: Unplanned => Sysadmin Contract 2024-I
* resolution: => fixed
* status: new => closed
Comment:
Closing as completed
Keywords: |
Comment (by strk):
For the record, now Ansible does the deploy too:
deployment/commit/8a7dbe136f13edcc6aa8b02df2ab56a861ec135a
Keywords: |
Comment (by strk):
And we do use the same url for common assets of every trac environment too
now,
with https://git.osgeo.org/gitea/sac/ansible-
deployment/commit/741a6f2e41c54e808bbaf25b673bec9f0507cbb6
AND with droppign the local override of htdocs_location in each env's
trac.ini
Keywords: |
Comment (by strk):
Reopening as it's happening again.
It may be a segfault of apache.
