#3286: gitea git commit hooks failing to trac upgrade of
trac.db.api.DatabaseManager
Reporter: robe | Owner: strk
Type: task | Status: new
Priority: normal | Milestone:
Component: SysAdmin/Trac | Keywords:
We've been having this issue on trac since recent upgrades that gitea
commit hooks to trac are failing with
Error: Unable to check for upgrade of trac.db.api.DatabaseManager:
TimeoutError: Unable to get database connection within 0 seconds.
making the calls directly via trac-admin works fine.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3286>
OSGeo <Gter - OSGeo;
Component: SysAdmin/Trac | Resolution:
Keywords: |
Comment (by strk):
For the record it took me 3 reloads to see this ticket, first attempts all
gave me the "cannot get db connection within 0 seconds" error.
I wanted to say that manually running trac-admin usually works for me,
I've continued using this workaround and it seemed to always work, while
the git log seems to always fail. It would probably be wise to file a
ticket upstream to trac itself to see if they have any hint about it.
Ticket URL: <#3286 (gitea git commit hooks failing to trac upgrade of trac.db.api.DatabaseManager) – OSGeo;
Keywords: |
Comment (by robe):
reported upstream - #13793 (gitea git commit hooks failing to trac upgrade of trac.db.api.DatabaseManager) – The Trac Project
Keywords: |
Comment (by robe):
Upstream walked me thru adding some logging in the python code around
debugging db and also to turn on db logging.
The logs now show this as the culprit
psycopg2.OperationalError: connection to server on socket
"/var/run/postgresql/.s.PGSQL.5432" failed: fe_sendauth: no password
supplied
Why it doesn't trigger that when tracadmin is called directly using the
same accounts gitea is using is a bit puzzling.
Keywords: |
Comment (by robe):
I confirmed that is the issue cause when I set to trust for local
connection in /etc/postgresql/16/main/pg_hba.conf it worked fine.
I checked and the git account does have a .pgpass entry for trac account
for all databases and it can connect to all databases. But I guess for
some reason maybe psyqcopg2 can't access the file or it's running under
another account when it does tracadmin call.
Keywords: |
Comment (by robe):
For now I just put in the trac password in the
/var/www/trac/env/postgis/trac.ini file and that seems to work okay. I
also turned postgres logging back to what it was since the postgresql.log
had ballooned to over 90GB.
Type: task | Status: closed
Priority: normal | Milestone: Sysadmin Contract 2024-I
Component: SysAdmin/Trac | Resolution: fixed
Keywords: |
Changes (by robe):
* milestone: => Sysadmin Contract 2024-I
* resolution: => fixed
* status: new => closed
Comment:
Okay issue resolved. Troubleshooted with lnicola and strk by adding env
logging to the postgis git hook to see what environment variables it was
using.
added to the top of /home/git/gitea-repositories/postgis/postgis.git/hooks
/post-receive.d/osgeo
env > /home/git/env_from_git
Turns out that gitea overrides the HOME variable to:
HOME=/home/git/gitea/data/home
So it was expecting the .pgpass file to be there instead of
/home/git/.pgpass. Copying the .pgpass there fixed the issue.
Keywords: |
Comment (by strk):
Do you have any idea when did Gitea start changing HOME ? I ask because
before the system upgrade things were working and I don't think we
upgraded Gitea ?
Keywords: |
Comment (by robe):
Replying to [comment:10 strk]:
upgraded Gitea ?
Yah totally baffling. We did not upgrade gitea and gitea service script
/etc/init.d/gitea I don't think we changed either. So I still think
somehow the upgrade changed how it determines home for service scripts.
I would expect home to be what this returns
sudo -u git bash -c 'echo $HOME'
But that returns the expected /home/git
not the /home/git/gitea/data/home that gitea seems to be using.
Perhaps it's some conditional code that gitea is hitting as a result of OS
upgrade that wasn't being exercised before.
