[OSGeo] #3306: Upgrade discourse mail-receiver app
Reporter: robe | Owner: sac-tickets@…
     Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2024-I
Component: SysAdmin/Discourse | Keywords:
Looks like our discourse mail-receiver app hasn't been updated in a while
and quite a few changes since.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3306&gt;
OSGeo <Gter - OSGeo;
Component: SysAdmin/Discourse | Resolution:
Keywords: |
Comment (by robe):
Upgraded with
docker pull discourse/mail-receiver:release
cd /var/discourse
#this tries to update anyway
./launcher rebuild mail-receiver
Ticket URL: <#3306 (Upgrade discourse mail-receiver app) – OSGeo;
     Type: task | Status: reopened
Keywords: |
Changes (by robe):
* resolution: fixed =>
* status: closed => reopened
Comment:
I seem to be missing the last note from this ticket and logs show that
discourse might be not fully trusting trac.
I'm going to switch osgeo.org to use mail.osgeo.org to see if that helps
any
Oct 27 03:57:07 discourse-mail-receiver postfix/cleanup[141]: 8B33D18B01C:
message-id=<___>
<22>Oct 27 03:57:07 opendmarc[39]: implicit authentication service:
discourse-mail-receiver.localdomain<22>Oct 27 03:57:07 opendmarc[39]:
8B33D18B01C: osgeo.org failOct 27 03:57:07 discourse-mail-receiver
postfix/qmgr[120]: 8B33D18B01C: from=<___>, size=2404,
nrcpt=1 (queue active)
Oct 27 03:57:07 discourse-mail-receiver postfix/smtpd[135]: disconnect
from secure.osgeo.osuosl.org[140.211.15.57] ehlo=1 mail=1 rcpt=1 data=1
quit=1 commands=5
<23>Oct 27 03:57:07 receive-mail[143]: Recipient: sac-
___ 27 03:57:07 discourse-mail-receiver
postfix/pipe[142]: 8B33D18B01C: to=<___>,
relay=discourse, delay=0.74, delays=0.35/0.01/0/0.38, dsn=2.0.0,
status=sent (delivered via discourse service)
Oct 27 03:57:07 discourse-mail-receiver postfix/qmgr[120]: 8B33D18B01C:
removed
Keywords: |
Comment (by robe):
After changing smtp host and tls setting
Keywords: |
Comment (by robe):
after changing to mail.osgeo.org
     Type: task | Status: closed
Component: SysAdmin/Discourse | Resolution: fixed
Keywords: |
Changes (by robe):
* resolution: => fixed
* status: reopened => closed
Keywords: |
Changes (by robe):
* status: new => closed
Comment:
Just did a test to confirm it is working as there seemed to be a delay
receiving sac.
The sac eventually came thru though.
It looks like it's now doing more intensive checks of spf and dmarc.
I'll monitor to see if this helps any with the spam I was seeing in www-
info
To check I've been using this
docker logs mail-receiver f
I see this:
<22>Oct 27 03:44:02 opendkim[24]: OpenDKIM Filter v2.11.0 starting (args:
-x /etc/opendkim.conf)Adding user `postfix' to group `opendmarc' ...
<86>Oct 27 03:44:02 usermod[31]: add 'postfix' to group 'opendmarc'<86>Oct
27 03:44:02 usermod[31]: add 'postfix' to shadow group 'opendmarc'Done.
<22>Oct 27 03:44:02 opendmarc[39]: OpenDMARC Filter v1.4.2 starting (args:
-c /etc/opendmarc.conf)<22>Oct 27 03:44:02 opendmarc[39]: additional
trusted authentication services: (none)postfix: Postfix is using
backwards-compatible default settings
Oct 27 03:44:02 discourse-mail-receiver postfix[51]: Postfix is using
postfix: See Postfix Backwards-Compatibility Safety Net for details
Oct 27 03:44:02 discourse-mail-receiver postfix[51]: See
postfix: To disable backwards compatibility use "postconf
compatibility_level=3.6" and "postfix reload"
Oct 27 03:44:02 discourse-mail-receiver postfix[51]: To disable backwards
compatibility use "postconf compatibility_level=3.6" and "postfix reload"
Starting Postfix
Oct 27 03:44:03 discourse-mail-receiver postfix/master[1]: daemon started
-- version 3.7.11, configuration /etc/postfix
Oct 27 03:54:00 discourse-mail-receiver postfix/smtpd[122]: warning:
hostname 188-190-10-253.clevhosting.com does not resolve to address
188.190.10.253: Name or service not known
Oct 27 03:54:00 discourse-mail-receiver postfix/smtpd[122]: connect from
unknown[188.190.10.253]
Oct 27 03:54:00 discourse-mail-receiver postfix/smtpd[122]: lost
connection after AUTH from unknown[188.190.10.253]
Oct 27 03:54:00 discourse-mail-receiver postfix/smtpd[122]: disconnect
from unknown[188.190.10.253] ehlo=1 auth=0/1 commands=1/
So it looks like it's doing some dmarc, spf checks now, but probably some
things we need to configure with POSTCONF_ variables to get rid of some of
those warnings.
I'll open a separate ticket for that.
