#3314: general and gdal matrix rooms disconnected from slack
Reporter: robe | Owner: sac-tickets@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2024-I
Component: SysAdmin | Keywords:
We upgraded osgeo:general and osgeo:matrix rooms to version 10 on matrix.
Immediately after slack General and slack gdal were disconnected from
matrix.
It seemed initially all was good, but after the first message to general
after the upgrade second message and subsequent messages became
disconnected from slack. In some sort of split brain it seems.
I'm not sure if it's the version 10 (maybe slack can't handle that, as the
other rooms mirrored on slack that still work - postgis, geos) are version
9.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3314>
OSGeo <Gter - OSGeo;
Component: SysAdmin | Resolution:
Keywords: |
Description changed by robe:
Old description:
matrix.
the other rooms mirrored on slack that still work - postgis, geos) are
version 9.
New description:
We upgraded osgeo:general and osgeo:matrix rooms to version 11 on matrix.
matrix.
9.
1. Had to install Integration widget in my element, so I see the linkages.
2. Annoyingly when I went to the old room, I saw no Slack Bridge
installed, so I added it, then got the option to unlink. So unlinked
