[OSGeo] #3331: Can OsGeo-Oceania channel be added to the Matrix Bridge?
Reporter: xuid0 | Owner: sac-tickets@…
Priority: normal | Milestone: Unplanned
Component: SysAdmin | Keywords: Matrix, sys-admin, feature-request
Hi.
I have investigated where to ask this and it lead me to this trac page.
Could I ask for the relevant channels for: https://osgeo-oceania.org
/openstreetmap-osm-state-of-the-map-sotm be added to this Bridge software
if possible? To allow me and others to use a Matrix client to access the
relevant OsGeo Oceania Slack channels without using Slack app.
Thank you
Xuid0.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3331&gt;
OSGeo <Gter - OSGeo;
                                                | tickets@…
Component: SysAdmin | Resolution:
Keywords: Matrix, sys-admin, feature-request |
Changes (by xuid0):
* Attachment "Screenshot_20250108-084604.png" added.
Screenshot of all Slack channels needed on Bridge if possible?
                                                | tickets@…
Comment (by robe):
Unfortunately I don't thik this is doable because the slack instance is
under a different org from OSGeo. The way our matrix/slack bridge works,
there is a matrix plugin (which actually I think is deprecated these days
so we probably need to revisit that) on slack and then integration on the
osgeo matrix side. When I set up a bridge I have to be admin of both
orgs, and I only get an option to associate a slack channel hosted on
osgeo.org slack org, with matrix channel aliased or hosted on our osgeo
matrix.
@strk correct me if I am wrong and there is a way.
Ticket URL: <#3331 (Can OsGeo-Oceania channel be added to the Matrix Bridge?) – OSGeo;
                                                | tickets@…
Comment (by xuid0):
I guess mautrix-discord - mautrix-bridges
mautrix-slack - mautrix-bridges
Neither of this software can be implemented or is possible to be
implemented?
Reporter: Josh G | Owner: sac-
                                                | tickets@…
Comment (by strk):
I guess whoever has admin power on both Matrix room and Slack server can
setup the bridge. The bridge service isn't run by OSGeo but by matrix.org
itself and is accessible via Element Web (app.element.im)
I don't have those powers so cannot help.
                                                | tickets@…
     Type: enhancement | Status: closed
Component: SysAdmin | Resolution: wontfix
Changes (by robe):
* resolution: => wontfix
* status: new => closed
Comment:
Okay closing this out. I think this has to be done by OpenStreetMap folks
since they are presumably admins of the Slack. At anyrate needs to be
discussed on the oceania mailing list as jsanz mentioned in #3332.
Presumably someone there will know more about this.
Feel free to reopen if you find out we can do something on our end.
