#3447: lists.osgeo.org: SPF fail - not authorized
Reporter: neteler | Owner: sac-tickets@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: SysAdmin | Keywords: mail, mailman, SFP
Today, being mailman list administrator of "grass-psc", I have received:
<mXXXXXXXXX.cYYYYYY@supsi.ch>: host mailgw2.supsi.ch[195.176.78.201] said:
550 5.7.23 <SRS0=1wg2=4J=lists.osgeo.org=grass-psc-bounces@osgeo.org>:
Sender address rejected: Message rejected due to: SPF fail - not
authorized. Please see
Libraesva - SPF Why?
(in reply to RCPT TO command)
Is there a way to fix this SFP issue?
Ticket URL: <Making sure you're not a bot!;
OSGeo <Gter - OSGeo;
Component: SysAdmin/DNS | Resolution:
Keywords: mail, mailman, SFP |
Changes (by robe):
* component: SysAdmin => SysAdmin/DNS
Comment:
Strange looks like mail is going thru the osgeo9 .13 address
Here's what you can do: Contact the lists.osgeo.org postmaster and tell
them that they need to change lists.osgeo.org SPF record so that it
authorizes osgeo9.osgeo.osuosl.org (140.211.15.13). They should add this
to their SPF record:
a:osgeo9.osgeo.osuosl.org
Current SPF record:
v=spf1 mx a:mail.osgeo.org ip4:10.36.74.210 ip4:140.211.15.3
ip4:140.211.15.14 -all
I guess we can add the .13 and should fix the issue. It was probably a hit
or miss issue as I suppose it could broadcast any ip on the machine it is
hosted on.
Comment (by strk):
I think for now let's add all osgeo9 IP addresses to the SPF record, yes.
Those records are managed via Ansible:
deployment/src/branch/master/deployment/roles/dns-
records/defaults/main/spf.yml#L10
Comment (by strk):
Given that osgeo9 has multiple IP addresses we could probably drop the
hostname (the a:osgeo9.osgeo.osuosl.org) and only use the ip4 components.
Type: task | Status: closed
Component: SysAdmin/DNS | Resolution: fixed
Changes (by robe):
* resolution: => fixed
* status: new => closed
Comment:
Done in ansible - and pushed Making sure you're not a bot!
deployment/commit/9d26c7626dc3343061757b7b884c71554500c97a
Note made a change in osgeo_org that wasn't necessary so reverted that in:
deployment/commit/82146761c122bc9a2de1d2477c833677d0c2267f
I'm going to leave it as is for now too lazy to change again.
Comment (by robe):
One more mistake fixed in Making sure you're not a bot!
deployment/commit/a9cda41a92af491f367e72894e5de1b84efe1190
@strk I think we should keep the osgeo9.osgeo.osuosl.org one. That is an
ip address we don't control and if per chance OSU needs to change the ip,
we want mail to still work going thru it.
Comment (by strk):
Regina we should know if we change IP address as those are also set via
Ansible, right ?
