[OSGeo-Announce] Announce of release PROJ 7.2.0 & PROJ-data 1.3
see also https://www.osgeo.org/foundation-news/announce-release-of-proj-7-2-0-and-proj-data-1-3/
On behalf of the PROJ development team I am happy to announce the release
of PROJ 7.2.0 and PROJ-data 1.3.
The PROJ release includes a number of improvements, new features and bug
fixes. See the detailed release notes below. The PROJ-data package includes adds
new resources for Finish TIN shift transformations as well as the Japanese
GSIGEO2011 geoid.
Get the packages here:
http://download.osgeo.org/proj/proj-7.2.0.tar.gz
http://download.osgeo.org/proj/proj-7.2.0.zip
http://download.osgeo.org/proj/proj-data-1.3.tar.gz
http://download.osgeo.org/proj/proj-data-1.3.zip
/Kristian Evers
7.2.0 Release Notes
  Updates
  + Command line tools:
    o Add multi-line PROJ string export capability, and use it by default in
      projinfo (unless --single-line is specified) (#2381)
  + Coordinate operations:
     o +proj=col_urban projection, implementing a EPSG projection method
       used by a number of projected CRS in Colombia (#2395)
     o +proj=tinshift for triangulation-based transformations (#2344)
     o Added ellipsoidal formulation of +proj=ortho (#2361)
  + Database
    o Update to EPSG 10.003 and make code base robust to dealing with
      WKT CRS with DatumEnsemble (#2370)
    o Added Finland tinshift operations (#2392)
    o Added transformation from JGD2011 Geographic 3D to JGD2011
      height using GSIGEO2011 (#2393)
    o Improve CompoundCRS identification and name morphing in VerticalCRS
      with ESRI WKT1 (#2386)
    o Added OGC:CRS27 and OGC:CRS83 CRS entries for NAD27 and NAD83
      in longitude, latitude order (#2350)
  + API
  o Added temporal, engineering, and parametric datum
    PJ_TYPE enumerations (#2274)
   o Various improvements to context handling (#2329, #2331)
   o proj_create_vertical_crs_ex(): add a ACCURACY option to provide
      an explicit accuracy, or derive it from the grid name if it is
      known (#2342)
    o proj_crs_create_bound_crs_to_WGS84(): make it work on
      verticalCRS/compoundCRS such as EPSG:4326+5773 and
      EPSG:4326+3855 (#2365)
    o promoteTo3D(): add a remark with the original CRS identifier (#2369)
    o Added proj_context_clone (#2383)
  Bug fixes
  o Avoid core dumps when copying contexts in certain scenarios (#2324)
  o proj_trans(): reset errno before attemptying a retry with a new
    coordinate operation (#2353)
  o PROJJSON schema corrected to allow prime meridians values with
    explicitly stating a unit (degrees assumed) (#2354)
  o Adjust createBoundCRSToWGS84IfPossible() and operation filtering
    (for POSGAR 2007 to WGS84 issues) (#2357)
  o createOperations(): several fixes affecting NAD83 -> NAD83(2011) (#2364)
  o WKT2:2019 import/export: handle DATUM (at top level object) with PRIMEM
  o WKT1_ESRI: fix import and export of CompoundCRS (#2389)
