Happy new year everyone! What better than to celebrate with a new PROJ release.
The PROJ 6.3.0 release includes new features and a range of bug fixes. Download
the archives here:
https://download.osgeo.org/proj/proj-6.3.0.tar.gz (https://download.osgeo.org/proj/proj-6.3.0.tar.gz.md5
https://download.osgeo.org/proj/proj-6.3.0.zip (https://download.osgeo.org/proj/proj-6.3.0.zip.md5
See the release notes below.
In addition to the PROJ release we are also issuing releases of three regional
datumgrid packages:
Oceania-1.1:
http://download.osgeo.org/proj/proj-datumgrid-oceania-1.1.zip
- Added AUSGeoid98, AUSGeoid09 & AUSGeoid2020
- Added various grids for New Zealand
- Added GDA94_GDA2020 grids for Christmas and Coco Island
North-America-1.3:
http://download.osgeo.org/proj/proj-datumgrid-north-america-1.3.zip
- Added Quebec grids na27na83.gsb and cq77na83.gsb
- Added MAY76V20.gsb for Canadian NAD27(76)->NAD83 transformations
- Added Canadian geoid models for CGVD28, CGVD2013(CGG2013) and CGVD2013(CGG2013a)
- Added Canadian provincial horizontal shift grids
- Added USA geoid models 1999, 2003, 2006, 2009 and 2018
Europe-1.5:
http://download.osgeo.org/proj/proj-datumgrid-europe-1.5.zip
- Added SeTa2016.gsb for DE_DHDN → ETRS89 in Saarland
- Added 100800401.gsb for Catalonia ED50 → ETRS89
- Added NTv2_SN.gsb for RD/83 to ETRS89 in Saxony
- Added AT_GIS_GRID.gsb for Austria MGI->ETRS89
- Added various grids for Iceland, including ISL init file
- Added BWTA2017.gsb for DHDN->ETRS89 for Baden-Württemberg
- Addedvertical grids for Saint-Pierre-et-Miquelon: RASPM2018 and CGVD2013RGSPM06
- Added NTv2 grids for convertion between Portuguese Lisbon Datum and Datum 73 to ETRS89
6.3.0 Release Notes
Updates
o Database: tune accuracy of Canadian NTv1 file w.r.t NTv2 (#1812)
o Modify verbosity level of some debug/trace messages (#1811)
o projinfo: no longer call createBoundCRSToWGS84IfPossible() for WKT1:GDAL
(#1810)
o proj_trans: add retry logic to select other transformation if the best one
fails. (#1809)
o BoundCRS::identify(): improvements to discard CRS that aren’t relevant
(#1802)
o Database: update to IGNF v3.1.0 (#1785)
o Build: Only export symbols if building DLL (#1773)
o Database: update ESRI entries with ArcGIS Desktop version 10.8.0 database
(#1762)
o createOperations(): chain operations whose middle CRSs are not identical but
have the same datum (#1734)
o import/export PROJJSON: support a interpolation_crs key to geoid_model
(#1732)
o Database: update to EPSG v9.8.4 (#1725)
o Build: require SQLite 3.11 (#1721)
o Add support for GEOIDMODEL (#1710)
o Better filtering based on extent and performance improvements (#1709)
Bug fixes
o Horizontal grid shift: fix issue on iterative inverse computation when
switching between (sub)grids (#1797)
o createOperations(): make filtering out of ‘uninteresting’ operations less
aggressive (#1788)
o Make EPSG:102100 resolve to ESRI:102100 (#1786)
o ob_tran: restore traditional handling of +to_meter with pj_transform() and
proj utility (#1783)
o CRS identification: use case insensitive comparison for authority name
(#1780)
o normalizeForVisualization() and other methods applying on a ProjectedCRS: do
not mess the derivingConversion object of the original object (#1746)
o createOperations(): fix transformation computation from/to a CRS with
+geoidgrids and +vunits != m (#1731)
o Fix proj_assign_context()/pj_set_ctx() with pipelines and alternative coord
operations (#1726)
o Database: add an auxiliary concatenated_operation_step table to allow
arbitrary number of steps (#1696)
o Fix errors running gie-based tests in Debug mode on Windows (#1688)
