[OSGeo-Announce] PROJ 7.0.1 & 6.3.2 released (2020-05-01)
News item by Kristian Evers 2020-05-01
see also: https://www.osgeo.org/foundation-news/proj-7-0-1-6-3-2-released-2020-05-01/
On behalf of the PROJ development team I am happy to announce the release
of both PROJ 6.3.2 and 7.0.1. These are both bug fix releases and should
provide a more stable experience for PROJ users on both the 6.3 and 7.0
branches.
See release notes below for details. Download the source distributions here:
https://download.osgeo.org/proj/proj-6.3.2.tar.gz.md5)
https://download.osgeo.org/proj/proj-6.3.2.zip.md5)
https://download.osgeo.org/proj/proj-7.0.1.tar.gz.md5)
https://download.osgeo.org/proj/proj-7.0.1.zip.md5)
7.0.1 Release Notes
Updates
o Database: update to EPSG v9.8.9 (#2141)
Bug fixes
o Make tests independent of proj-datumgrid (#1995)
o Add missing projection property tables (#1996)
o Avoid crash when running against SQLite3 binary built with
  -DSQLITE_OMIT_AUTOINIT (#1999)
o createOperations(): fix wrong pipeline generation with CRS that has +nadgrids=
  and +pm= (#2002)
o Fix bad copy&replace pattern on HEALPix and rHEALPix projection names (#2007)
o createUnitOfMeasure(): use full double resolution for the conversion
  factor (#2014)
o Update README with info on PROJ-data (#2015)
o utm/ups: make sure to set errno to PJD_ERR_ELLIPSOID_USE_REQUIRED if
  es==0 (#2045)
o data/Makefile.am: remove bashism (#2048)
o ProjectedCRS::identify(): tune it to better work with ESRI WKT
  representation of EPSG:2193 (#2059)
o Fix build with gcc 4.8.5 (#2066)
o Autotools/pkg-conf: Define datarootdir (#2069)
o cs2cs: don't require +to for '{source_crs} {target_crs} filename...'
  syntax (#2081)
o CMake: fix bug with find_package(PROJ) with macOS (#2082)
o ESRI WKT import / identification: special case for
  NAD_1983_HARN_StatePlane_Colorado_North_FIPS_0501 with Foot_US unit (#2088)
  NAD_1983_HARN_StatePlane_Colorado_North_FIPS_0501 with Foot_US unit (#2089)
o EngineeringCRS: when exporting to WKT1_GDAL, output unit and axis (#2092)
o Use jtsk03-jtsk horizontal grid from CDN (#2098)
o CMake: prefer to use use PROJ_SOURCE_DIR and PROJ_BINARY_DIR (#2100)
o Fix wrong grids file name in esri.sql (#2104)
o Fix identification of projected CRS whose name is close but not strictly
  equal to a ESRI alias (#2106)
o Fix working of Helmert transform between the horizontal part of
  2 compoundCRS (#2111)
o Database: fix registration of custom entries of grid_transformation_custom.sql
  for geoid grids (#2114)
o ESRI_WKT ingestion: make sure to identify to non-deprecated EPSG entry when
  possible (#2119)
o Make sure that importing a Projected 3D CRS from WKT:2019 keeps the base
  geographic CRS as 3D (#2125)
o createOperations(): improve results of compoundCRS to compoundCRS case (#2131)
o hgridshift/vgridshift: defer grid opening when grid has already
  been opened (#2132)
o Resolve a few shadowed declaration warnings (#2142)
o ProjectedCRS identification: deal with switched 1st/2nd std parallels for
  LCC_2SP(#2153)
o Fix Robinson inverse projection (#2154)
o createOperations(): do not remove ballpark transformation if there are only
  grid based operations, even if they cover the whole area of use (#2156)
o createFromCoordinateReferenceSystemCodes(): 'optimization' to avoid using
  C++ exceptions (#2161)
o Ingestion of WKT1_GDAL: correctly map 'Cylindrical_Equal_Area' (#2167)
o Add limited support for non-conformant WKT1 LAS COMPD_CS (#2172)
o PROJ4 string import: take into correctly non-metre unit when the string
  looks like the one for WGS 84 / Pseudo Mercator (#2177)
o io.hpp: avoid dependency to proj_json_streaming_writer.hpp (#2184)
o Fix support of WKT1_GDAL with netCDF rotated pole formulation (#2186)
6.3.2 Release Notes
Bug fixes
o validateParameters(): fix false-positive warning on
  Equidistant Cylindrical (#1947)
o proj_create_crs_to_crs(): avoid potential reprojection failures when
  reprojecting area of use to source and target CRS (#1993)
  and +pm= (#2003)
o Fix bad copy&replace pattern on HEALPix and rHEALPix projection names (#2006)
  factor (#2013)
o data/Makefile.am: remove bashism (#2047)
o ProjectedCRS::identify(): tune it to better work with ESRI WKT representation
  of EPSG:2193 (#2058)
o EngineeringCRS: when exporting to WKT1_GDAL, output unit and axis (#2091)
o Add missing entries in grid_alternatives for Portugal grids coming from
  ESRI entries (#2103)
o Fix working of Helmert transform between the horizontal part of 2
  compoundCRS (#2110)
  possible (#2118)
  geographic CRS as 3D (#2124)
o createOperations(): improve results of compoundCRS to compoundCRS case (#2130)
o PROJ4 string import: take into correctly non-metre unit when the string looks
  like the one for WGS 84 / Pseudo Mercator (#2178)
o Fix support of WKT1_GDAL with netCDF rotated pole formulation (#2187)
o io.hpp: avoid dependency to proj_json_streaming_writer.hpp (#2188)
