*News item by Kristian Evers*
Published at [https://www.osgeo.org/foundation-news/proj-7-2-1-proj-data-1-4/](https://www.osgeo.org/foundation-news/proj-7-2-1-proj-data-1-4/)
On behalf of the PROJ development team I am happy to announce the release of PROJ 7.2.1 and PROJ-data 1.4.
The PROJ release includes updates to the database and a number of bug fixes.
See the detailed release notes below.
The PROJ-data package adds two new grid files (au_ga_AGQG_20191107.tif and eu_nkg_nkgrf2017vel.tif) that are referenced in the database updates.
Get the packages here:
http://download.osgeo.org/proj/proj-7.2.1.tar.gz
http://download.osgeo.org/proj/proj-7.2.1.zip
http://download.osgeo.org/proj/proj-data-1.4.tar.gz
http://download.osgeo.org/proj/proj-data-1.4.zip
/Kristian
7.2.1 Release Notes
Updates
o Add metadata with the version number of the database layout (#2474)
o Split coordinateoperation.cpp and test_operation.cpp in several parts (#2484)
o Update to EPSG v10.008 (#2490)
o Added the NKG 2008 and 2020 transformations in proj.db (#2495)
Bug fixes
o Set CURL_ENABLED definition on projinfo build (#2405)
o createBoundCRSToWGS84IfPossible(): make it return same result with a CRS
built from EPSG code or WKT1 (#2412)
o WKT2 parsing: several fixes related to map projection parameter units (#2428)
o createOperation(): make it work properly when one of the CRS is a BoundCRS of
a DerivedGeographicCRS (+proj=ob_tran +o_proj=lonlat +towgs84=…) (#2441)
o WKT parsing: fix ingestion of WKT with a Geocentric CRS as the base of the
projected CRS (#2443)
o GeographicCRS::_isEquivalentTo(EQUIVALENT_EXCEPT_AXIS_ORDER_GEOGCRS):
make it work when comparing easting,northing,up and northing,easting,up (#2446)
o createOperation(): add a ballpark vertical transformation when dealing
with GEOIDMODEL (#2449)
o Use same arguments to printf format string for both radians and degrees in
output by cct (#2453)
o PRIMEM WKT handling: fixes on import for ‘sexagesimal DMS’ or from WKT1:GDAL/ESRI
when GEOGCS UNIT != Degree; morph to ESRI the PRIMEM name on export (#2455)
o createObjectsFromName(): in exact match, make looking for ‘ETRS89 / UTM zone 32N’
return only the exact match (#2462)
o Inverse tmerc spherical: fix wrong sign of latitude when lat_0 is used (#2469)
o Add option to allow export of Geographic/Projected 3D CRS in WKT1_GDAL (#2470)
o Fix building proj.db with SQLite built with -DSQLITE_DQS=0 (#2480)
o Include JSON Schema files in CMake builds (#2485)
o createOperations(): fix inconsistent chaining exception when transforming from BoundCRS of projected CRS based on NTF Paris to BoundCRS of geog CRS NTF Paris (#2486)
