All,
It is our pleasure to announce the release of PROJ version 5.1.0. This
release includes both new features and bug fixes in PROJ. See the
release notes below for details.
Downloads are here:
http://download.osgeo.org/proj/proj-5.1.0.tar.gz
(http://download.osgeo.org/proj/proj-5.1.0.tar.gz.md5)
http://download.osgeo.org/proj/proj-5.1.0.zip
(http://download.osgeo.org/proj/proj-5.1.0.zip.md5)
Thanks to everyone who contributed to this release.
The PROJ dev team
5.1.0 Release Notes
UPDATES
o Function proj_errno_string() added to proj.h API (#847)
o Validate units between pipeline steps and ensure transformation
sanity (#906)
o Print help when calling cct and gie without arguments (#907)
o CITATION file added to source distribution (#914)
o Webmercator operation added (#925)
o Enhanced numerical precision of forward spherical Mercator near
the Equator (#928)
o Added --skip-lines option to cct (#923)
o Consistently return NaN values on NaN input (#949)
o Removed unused src/org_proj4_Projections.h file (#956)
o Java Native Interface bindings updated (#957, #969)
o Horizontal and vertical gridshift operations extended to
the temporal domain (#1015)
BUG FIXES
o Handle nan float cast overflow in PJ_robin.c and nad_intr.c (#887)
o Avoid overflow when Horner order is unreasonably large (#893)
o Avoid unwanted NaN conversions in etmerc (#899)
o Avoid memory failure in gie when not specifying x,y,z in gie files (#902)
o Avoid memory failure when +sweep is initialized incorrectly in geos (#908)
o Return HUGE_VAL on erroneous input in ortho (#912)
o Handle commented lines correctly in cct (#933)
o Avoid segmentation fault when transformation coordinates outside grid
area in deformation (#934)
o Avoid doing false easting/northing adjustments on cartesian
coordinates (#936)
o Thread-safe creation of proj mutex (#954)
o Avoid errors when setting up geos with +lat_0!=0 (#986)
o Reset errno when running proj in verbose mode (#988)
o Do not interpolate node values at nodata value in vertical
grid shifts (#1004)
o Restrict Horner degrees to positive integer values to avoid
memory allocation issues (#1005)
All bug fix numbers refer to issues or pull requests indexed at
https://github.com/OSGeo/proj.4/
THANKS TO
Version 5.1.0 is made possible by the following contributors:
Kristian Evers
Even Rouault
Kurt Schwehr
Mike Toews
Martin Desruisseaux
Charles Karney
Thomas Knudsen
Javier Goizueta
Bas Couwenberg
Adam Wulkiewicz
Aaron Puchert
