Out of Memory in v.support?
Hi folks,
I'm having trouble creating support files for some DLG-3 soils data.
When I run v.import, it executes without problems, but then any attempt
(v.stats or d.vect) to use the files so created ends quickly with the
unexciting result, "Out of Memory."
If I use v.in.dlg to create the dig and the dig_att file, I can display
the results, and they look OK. But if I then run v.support or use
option 4 of v.import to generate the dig_plus file, I get the "Out of
Memory" problem again. So the problem seems to be in creating the
the file topology.
We're running on IBM RS6000's, a platform with a rich variety of
identified holes, so this could easily be system specific.
The goal of this is to create raster files, so it seems I need the
dig_plus file. Any ideas? Thanks,
          Jim R. Hurst
          jhurst@ese.ogi.edu
