In reply to:
Is there a way of overlaying vector maps on d.3d with
raster maps also. I would like to combine vector and raster map on top of
the 3-d display.
Daniel H. Rodriguez
Yes, there is. It's the SG3d module that you can get from the moon, which
allows you to overlay one cell, one vector, and one sites map at a time.
You can also overlay up to three cell maps as r, g, b layers, and you can
interactively change the vector and sites maps. It's quite easy to use. If
you don't have access to this module, things are going to become difficult.
You must then prepare a cell map by patching together rasterized vector and
sites maps and a cell map, and display them in the usual manner with d.3d.
The results will not be satisfactory - the 'vectors' will break up into cells.
Martijn van Leusen
