p.map help
The "end" following the "comments" should not be there. Check for a MASK.
Check your region vs the raster cell header carefully.
   "(west-east) >> (north-south)"
doesn't make sense to me. Can you clarify this please?
|Can someone tell me what's wrong with this input file to p.map?
|Using the preview driver, all that I get is a map on a gray
|background (no colortable and no comments). The map has only 4 cats...
|my region is set so that
|(i.e., image occupies all of panel in one direction, but there's
|plenty of space above and beneath). I'm sure that I'm doing something
|fundamentally wrong here... can you spot it?
| % p.map input=prescription
|filename: prescription
|> colormode approx
|> raster prescription.chem
|> colortable y
|> comments prescription.comments
|> end
|> outline
|> color black
|> end
|filename: prescription.comments
|> Spatial Prescription of Herbicides
|--jdm
Michael Shapiro U.S. Army CERL
email: shapiro@zorro.cecer.army.mil Environmental Division
phone: (217) 352-6511 ext 526 P.O. Box 9005
fax: (217) 373-7222 Champaign, Ill. 61826-9005
