p.map help
p.map drivers can either be unlimited in length (true printers)
or fixed in length (preview). The ppm driver is somewhat in
between since it isn't a true printer, just a file to be sent to
a printer later thru a conversion process unknown to p.map.
Therefore it is written to be fixed length. p.map will respond to
fixed length drivers by (1) ignoring any scale request amd (2)
not printing any off map text or graphics (commnets, color table,
etc). It is possbiel to change the behaviour of the ppm driver by
(1) writting code to create text and (2) changing it from a fixed
length driver to an unlimited length driver. (2) is easy but (1)
takes some work. I will report (1) and (2) as enhancement
requests for this driver (no promises, though).
|I tried the sample p.map script from the p.map man page. The
|output driver was ppm and I converted paint.ppm to both gray-
|scale and color postscript output. The script produces a pretty
|map but no legend and no comment. There were two inch long lines
|below the lower left corner of the map, one solid and one dashed.
|Furthermore, the 'scale' command did not seem to affect the
|output at all.
Michael
