I am trying to set up a tek4696 inkjet printer to a Sun SPARC2
To the best of my knowledge I've followed the instalation instructions through
editing the list/local file
compiling the drivers
linking the /dev files
chmod 0666 /dev/....
the ttytab file has been altered to turn getty off
the printer passes its own self test
p.select presents the expected choices
p.chart prompts to reset the plotter and hit return
everything seems to work
i get the GRASS 4.0 > prompt
but nothing happens at the printer
the same is true for p.map
any suggestions as to what i've done wrong ??
it doesn't seem to be that difficult
Tom Nelson
C.O.E
Ft. Worth Texas
