In reply to allan@oregon.uoregon.edu;
I have had success using the pbmplus tools (scr.alpha) in converting ppm to pcx
format - which I then could import into Wordperfect. Use the p.select "ppm"
option, create your p.map image; the file paint.ppm will be deposited in your
home directory. Then use ppmtopcx to convert.
Hope this helps.
Ronald Thomas
(ront@niwot.cfnr.colostate.edu)
Rocky Mountain National Park
Estes Park, CO
