The "legend", such as it is, is a string of boxes equal to the # of
categories in your raster map, with the number (not the text) of the
appropriate category next to it. You do not need to set a frame.
If you are planning to use p.map output for actual display, you will have
to do some "doctoring" of the legend (manually) .
You might want to look into MAPGEN for hardcopy output if you desire a more
"finished" product.
Ronald Thomas ^ ront@meeker.cfnr.colostate.edu
Natural Resources Spec. (GIS) ^
Resources Management Division ^ Phone: 303-586-3565 x285
Rocky Mountain National Park ^ 700-323-7285 (FTS)
Estes Park, CO 80517 ^ FAX: 303-586-4702
