p.map scale
From grass-lists-owner@max.cecer.army.mil Thu Mar 11 08:56:20 1993
Date: Thu, 11 Mar 93 11:48:57 -0500
Sender: lists-owner@max.cecer.army.mil
Reply-To: grassu-list@max.cecer.army.mil
Subject: Re: p.map scale
Content-Length: 289
Thanks, your tip seems (close) to doing the trick. My only problem now is that
I am losing the bottom frame line on the map. I still don't understand what
the 'scale' option in p.map.new does. Nothing that I assign to it seems to
affect the size of the hardcopy map. -- Cliff B
I had a similar problem and I submitted it to bugs.report. The answer was
that p.map is not intended to be used with the ppm programs and, so, we lose
the scale. Your scale would be respected if you were working with a driver for your printer. So, the answer you have got is the only solution. Nevertheless, although we can get quite easily a plot which would fit in one page, I was not able to get a particular predefined sclae (say 1:50000). p.map should be modified to
directly generate postscript as output.
